question about '90 accord tire
Old Aug 23, 2007 | 05:55 PM
soadmd88's Avatar
Default question about '90 accord tire
Okay so I am not completly automobile smart. I need some help. I have a 90 accord lx 4 dr sedan. When I let go of the steering wheel my car shifts to the right quite a bit. Can someone explain what needs to be done, do I need a wheel alignment? And I am also wondering what the tire pressure (psi) needs to be on the stock tires please help me out...
Old Aug 23, 2007 | 06:11 PM
Andryzzle's Avatar
Default Re: question about '90 accord tire (soadmd88)
like you said, either alignment or tire pressure could be your problem and the recommended tire pressure should be on the sidewall of your tire.
Old Aug 23, 2007 | 06:21 PM
Hammer99ex's Avatar
Default Re: question about '90 accord tire (Andryzzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andryzzle &raquo;</TD></TR><TR><TD CLASS="quote">like you said, either alignment or tire pressure could be your problem and the recommended tire pressure should be on the sidewall of your tire.</TD></TR></TABLE>
incorrect, the vehicle's required tire pressure is on a sticker inside the drivers side door. the pressure rating on the tire is more of a generic measurement.
if you are pulling to the right, then id say you need an alignment. your right front wheel is probably toed out, and it might have positive camber too...
or your rear wheels are dog tracking
Old Aug 23, 2007 | 06:36 PM
Andryzzle's Avatar
Default Re: question about '90 accord tire (Hammer99ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hammer99ex &raquo;</TD></TR><TR><TD CLASS="quote">
i dunno if i would exceed the tire manufacturer's recommendations though...
Old Aug 23, 2007 | 06:43 PM
soadmd88's Avatar
I just checked my tires they are general ameri g4s tires and are pretty worn out so I can't even read what is written on there...to be safe I am just going to get a wheel alignment I suppose... how much does it cost and where can I get it done?
Old Aug 24, 2007 | 05:13 PM
Jstall7543's Avatar
LoL ...to be safe I am just going to get a wheel alignment
Get new tires first, youll be shocked at the difference! If the tires are that old you may have a broken cord inside of the tire, witch increases the tire dia. causing the car to pull! Late Playa
benji7288
Nov 21, 2007 01:21 PM
.water
Apr 1, 2006 07:05 PM
free4frank
Jul 6, 2005 07:43 PM
SkRiBLaH
10
Feb 16, 2004 09:25 AM
PoonHunter
Jul 14, 2003 11:39 AM
