CEL HELP!
blink - Pause - blink -pause - blinks 17 times.
This is what ym ECU is blinking over and over its an obd0 Civic SI with d15b1, HF intake manifold Si ECU and Si distributor. thats exactly how the light is blinking I cant figure it out any Help?
I bought the car like that. here is the storey. The car ran fine the day I picked it up A few days later it started running like ****, Turned out it had a bad ground. Fixed that and got it running again and a few days ago it started running like **** I can be driving it and go to get on it and it will be like someone is pusing on the front of the car. it will get up to about 4RPMS and just start figting to want to go. Cel cam on and thats what its blinking, Tried a new mpa sensor, tried new distributor, Nothing Has fxed it. I Cleaned the plugs but IM thinking maybe it just needs new ones but not real sure they look fine to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">17 quick flases is code 17</TD></TR></TABLE>
wrong, code 17 is one long flash followed by seven quick flashes. OP maybe your reading it wrong, you should be able to get a Honda tech to at least check the code for free to just tell you the correct number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">blnk pause blink pause is code 20 </TD></TR></TABLE>
only if it's long blinks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_Si »</TD></TR><TR><TD CLASS="quote">I am almost positive that non obd ecus do not have the long blink (10s) but only have the ones blinks. so I would take that as a code 17</TD></TR></TABLE>
..ooops, looks like I have been on OBD 1 for too long
But like he said code 17 won't cause running problem so maybe the CEL is not even your problem anyway (you should still fix the VSS though). Take it to a Honda tech and let them figure it out for you, may be something simple?
