B18c1 Turbo Setup (nothing big)
REVISED: because I pulled my head out of my ***
What I have:
JDM GSR motors (b18c)
CTR cams
Blox intake manifold
YS1 transmisson
Excedy Stage 1 clutch
Test Pipe
2.5" custom catback (need to get another resonator now that the cat's off, too much rasp
Erick's racing chip in my P28 ECU
ARP headstuds(coming soon)
Getting:
Garrett T3/T4 turbo
Log manifold/Greddy manifold
Tail Wastegate
Custom 2.5" downpipe
Custom intercooler piping with as little cuplers as possible
Some sort of tuning program
Bigger injectors (not sure how big to go.)
LS or GSR transmission
HKS Blow off valve
Some sort of clutch that can handle the power but be good for Daily Driven
probably more small **** but thats all the big stuff.
Hoping to make 270+ WHP
Modified by GQej1 at 1:19 PM 8/30/2007
What I have:
CTR cams
YS1 transmisson
Test Pipe
)Erick's racing chip in my P28 ECU
Getting:
Garrett T3/T4 turbo
Tail Wastegate
HKS Blow off valve
obd1 or obd2? just cerious i was goin to go with a simalar set up, but i've decided to go with a b20 block and a gsr head, crv-tech and going to do a 350-400whp build, but let me know how ur b18 set up works for u.
ditch the FMU, its junk, neptune, AEM, HOndata, uberdata are all good alternatives, much safer, see what your tuner prefers, Cam gears are a waste of time and money in my opinion, exhaust is a little small but will work for only ~250whp And KEEP your tranny!
i dont think you going to want an fmu if your tuner wants to use it on his setups thats fine i would look into something else. def, keep your trans ls trannies are for the peopl running a good amount of power. your not going to need much to get what you want so you dont have to drop a ton of money on name brand parts enless you plan on going bigger down the road, trust me 250whp will get old real fast. youll want to run more boost eventually so i would buy parts assuming your going to want more.
whats your budget?
whats your budget?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GQej1 »</TD></TR><TR><TD CLASS="quote">
B18c1 (JDM w/Higher compression than USDM)
i think that makes it a B18C
Turbo for a little over 225 WHP
lol you might as well stay N/A
seriously though. keep researching and you will get the setup straightened out. a stock block gsr is good for 300whp. and as mentioned above ditch the FMU, i dont care what your so called "tuner" says.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GQej1 »</TD></TR><TR><TD CLASS="quote">The thing is my tuner loves FMU's, he has a great setup and has run a ton of great setups with them. I've never seen any of his daily driven setups have problems. He has been running his little d series hatch for about 4 years with one.
Thanks for the input. I mentioned getting my ECU chipped but he told me not to. He can get me the power I need without it...safely. </TD></TR></TABLE>
hahah thats funny... i wouldn't even let him tune my car if he paid me.
he told you not to because he doesnt know how to tune a car. without a chipped ecu there is nothing to adjust lol. what exactly does he tune lol. i really hope he wasnt the one that told you to run larger injectors on a stock ecu with an fmu.
i notice at the end of your beginning post you say "and a good tune" you are eliminating any option of tuning. what is he gonna dial in the fuel pressure regulator lol.
also not sure how much the exedy stage one holds but i think thats more for an all motor setup.
i would pull a gun on this guy if he tried to get near my car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseriescivic5 »</TD></TR><TR><TD CLASS="quote">lol......i give the car 2 weeks to live......</TD></TR></TABLE>
youre being too reasonable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GQej1 »</TD></TR><TR><TD CLASS="quote">I know no one cares but I'm pretty much using this to put my thoughts down and maybe get some good advise.
Current setup in my 95 civic coupe:
CTR cams
B16 transmission (YS1)
Exedy Stage 1 clutch
2.5" header back (no cat)
Everything else is stock
I'm looking to:
I want to keep the AC and PS
Parts I think I need:
I want to get and LS transmission
Vortex FMU
Bigger injectors
t3/t4 turbo
HKS BOV
Slim intercooler and piping(flat blacked)
Greddy or Rev hard manifold
Downpipe
Tial Wastegate
Cam gears
Oil lines and T bolt clamps
AND A GOOD TUNE
I think thats all HAHA.
if yor motor is stamped B18C1 its a USDM motor not JDM. and if your tranny is a YS1 its a cable tranny, do you have cable tranny conversion?
CTR cams
I'm looking to:
Vortex FMU
Bigger injectors
t3/t4 turbo
HKS BOV
Downpipe
Tial Wastegate
Cam gears
AND A GOOD TUNE
you are a very generous man.
to the OP, there is a lot of good information on this thread heading you in the right direction. i hope you take some of it to heart, and not just ignore us.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93dagsr »</TD></TR><TR><TD CLASS="quote">B18C=JDM
B18C1=USDM
get it RIGHT!!!</TD></TR></TABLE>
Done
B18C1=USDM
Done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawlin »</TD></TR><TR><TD CLASS="quote">
whats your budget?</TD></TR></TABLE>
$1700....ish
$1700....ish
That really doesn't make sense.
</TD></TR></TABLE>That really doesn't make sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport »</TD></TR><TR><TD CLASS="quote">congrats GQej1 your arrogance will be the downfall of the project not the FMU. </TD></TR></TABLE> yeah, and maybe he should just stick to bolt-ons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GQej1 »</TD></TR><TR><TD CLASS="quote">Congrats.... I don't care. </TD></TR></TABLE>
then why are you here. you ask people that know what they are doing to critique your setup. we critique it and you tell us you dont care.
