mpfi swap help
1991 crx dx
car wont start after doing the swap ive triple check the instructions and wiring
i have tired both a 90 crx si computer and a 91 crx si computer. it has a distributor from 88 crx si. whats wierd is the starter wont crank and the battery has just been charged and i know the starter works for sure. it feels like its not getting spark, it is getting fuel and it set at top dead center and all plugs are plugged in. somebody please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redracer1024 »</TD></TR><TR><TD CLASS="quote">help
Any CELs?
Any CELs?
who did all the wiring? what wiring did you do in it? did you check the starter fuse in the fuse box or any of the other fuses. when i did my swap i blew the starter fuse under the dash. you might wanna check that out.
yes ive checked all fuses twice one by one i did the wiring exactly how all the dpfi to mpfi swap write ups that r on here thats why i dont understand how it could be so messed up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redracer1024 »</TD></TR><TR><TD CLASS="quote">yup checked it its like a ground definetly connected
so hold on... did you ground that terminal??? if you grounded it i beleave thats your problem. there is a wire from the ignition that runs to that.
check wires c1 and c2, actually double check all your new wires. so c1 and c2, then injector wirring a3 and a7. i got mine crossed a week ago when i did my swap. it happened when i ran them to the engine bay. Also check your solder connections. The two white wires on the distributor could be crossed.
no i didnt ground it i put it on the starter where it goes. i even tried giving the starter direct current from the battery and it wont do anything
