REAL QUICK! A/C question... fitment...
will an AC system from a 99 Civic EX fit a 95 EH2?
https://honda-tech.com/zeropost?cmd=reply&id=1910250
THANKS!
peaces.
THANKS!
peaces.
No the plumbing and wiring connectors are different.
Here is what you'll need:
Si Evaporator
92-93 (EG) A/C wiring harness
92-93 (EG) Thermo-SW (obvious reasons on the Si Evap is 3-Prong vs. 2-Prong)
92-93 (EG) Front A/C bracket(s) (Obvious reasons to hold the A/C Low pressure hose inplace under fender mount)
Si A/C Lines (ALL Plumbing, and I mean ALL)
Si Condenser
Si A/C Dryer/Accumulator
Si Relays (Controls Condensor Fan, High Pressure Switch, Compressor)
..... and last but not least 1/2" or 3/4" (both for a piece of mind) Pipe/Tube bender tool aprox $5.00 bucks and with lots of patience.
I think that's all ......
and if it needs modification, how much?
It's not the Wiring or the Evaporator installation nor the Condenser install thatis hard that's easy. The bending of the A/C lines at the front near the "lower core support" is what takes a while to custom fit so they do not rub or chaffe against anything. This is including the right amount of clearence from the radiator and the engine, that's it. Patience is needed, you don't want to bend those lines more than they are supossed to and no weird bends either, or you will have leaks easily and restrictions along your lines.
