using d16y8 intake on d15b2, what has to be done to make it work correctly?
Hey guys
so im changing my crx from dpfi to mpfi, im going to use a intake from a 98 d16y8, do i have to change over to obd-1 to use the injectors from this intake or is obd-0 ok, if they dont work will the injectors from a HF work ?? also will an si distributor work with this intake?
and last of all if i have to change it to obd-1 what will i need to buy and what will have to be done or changed
Thanks for the help
Ben
Thanks for the help
Ben
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superex87 »</TD></TR><TR><TD CLASS="quote">Hey guys
Thanks for the help
Ben
You need OBD0 injectors if you're going to run the resistor box. You may be able to just convert your injectors over to OBD1 right away, but I'd get clarification before you try that. OBD0 HF injectors would be fine with that if you want a to go the resistor box route.
The distributor will be fine.
Thanks for the help
Ben
use the injectors on the d16y8 manifold,just don't add the resistor box when you convert to mpfi.
also look at this site http://www.geocities.com/joeyp....html
Dandada
12
Apr 8, 2019 07:24 PM
slo_ej8
Apr 15, 2008 06:16 PM
