D16 I/M Question
Old Aug 23, 2007 | 09:17 AM
GSRHATCH!'s Avatar
Default D16 I/M Question
If you have a D15 Motor with the stock D15 Fuel rail & injectors will you have Idleing problems if you add a D16 I/M & TB? Should i upgrade the fuel system to d16 aswell or does it even matteR? i belive to fix the problem i have to get the car tune. But i'm trying to avoid this, what do you guys think i should do??
I'm getting a Air and Gas Mixture idleing problem, Car's idleing at around 3k rpm for about a sec then drops to 1k rpm. This is my reaccuring problem. hehe
Thanks for the help!!
Old Aug 23, 2007 | 09:20 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: D16 I/M Question (GSRHATCH!)
No, you can leave the stock fuel components.
You won't have idling problems unless you install it improperly.
I take it you currently have the vertical plenum and want the horizontal one.
It also sounds like you already have a vacuum leak though. If it does it constantly.
Old Aug 23, 2007 | 01:59 PM
GSRHATCH!'s Avatar
Default Re: D16 I/M Question (ek forever guy)
I'm missing a bolt on the bottom of the I/M could the be a problem?
Old Aug 23, 2007 | 02:00 PM
t0p_sh0tta's Avatar
It could...
Old Aug 23, 2007 | 07:54 PM
crimsonv4mpire's Avatar
get a new bolt, junk yards are great for that
4tika4
Mar 12, 2009 08:00 PM
hockeyMike2489
Jul 23, 2006 09:52 AM
redcivicek
Jan 12, 2004 09:39 AM
