CRX with 4 speed trany???
I have an L3 crx trany and it has only 4 speed, I never heard that crx came with 4 speeds !!! what year and what model is that crx ???
Do you guys know what is the spec on all 4 gears ???
Louis
Louis
a crx with a 4spd?
That would have to be an out of the US model or a swap from a civic std/cx.
It's the HF gears with out a 5th. Lose that tranny ASAP. Even if it's just to save gast get a HF tranny.
Thank you for the info.
Another question:
If I have a trany from a 88 crx si can I change the 5th gear only and use a taller gear??? I see the ZC engine has a better 5th, can I use that one or do you guys have any better idea on better 5th gear ???? how about the 5th gear from Delsol Vtec would that fit ion my L3 box???
Modified by ltblouis at 1:44 PM 8/23/2007
Another question:
yes, you can change 5th gear only - the ZC does not have a taller 5th - it is shorter - the HF has the taller 5th - also the 92-95 D-series (except Si HB and Del Sol Si, which are almost the same as 88-91 DX/Si) are taller
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Maxidermist »</TD></TR><TR><TD CLASS="quote">That would have to be an out of the US model or a swap from a civic std/cx.</TD></TR></TABLE>
btw, CX was 5spd
btw, CX was 5spd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing »</TD></TR><TR><TD CLASS="quote">
btw, CX was 5spd</TD></TR></TABLE> No, it was the canuck name for the STD here in the US.
Unless you are talking about later when the us got a cx badge on base model cars. But that's not in the 4th gen era.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Maxidermist »</TD></TR><TR><TD CLASS="quote"> No, it was the canuck name for the STD here in the US.
Yup, my bad. Forgot I was in the 4th gen forum. So used to being in 5th/6th gen forum.
jackjack23
Jun 19, 2014 11:44 PM
crx(gator)
Feb 7, 2003 11:13 AM
