EG6 Type-R PEDALS
I know clutch and gas are bolt on, brake isnt. ive heard that you have to just take the brake pedal its self and install it to its original pedal. another thing on the clutch do you remove the old bearing in the old pedal and install it in the new one? good tips would be helpful. thanks
on ek I cut welded gas pedal to original arm... brake & clutch I just riveted on covers. I had the factory optional type R/X (so they were made for RHD not LHD)
since then I learn my lesson & bought used s2k pedals for $50 shipped... going to rivet all 3 this time to eg assemblies
no need to replace bearings unless they are bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6SPD_EK »</TD></TR><TR><TD CLASS="quote">on ek I cut welded gas pedal to original arm... brake & clutch I just riveted on covers. I had the factory optional type R/X (so they were made for RHD not LHD)
no need to replace bearings unless they are bad </TD></TR></TABLE> nice
92-LS-Civic
Aug 18, 2004 11:34 AM
