D16A9 in the US???
I live In Peru (south america if you don´t know jajaja) I´ve been searchin for some information about my engine D16A9 but I haven´t found to much. This engine came here in the Civic Si 1.6 DOHC non- vtec. It´s a little extrange and hard to find information about it. Anyone who knows where to find? or, whta´s the equivalent in other engine code?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eduardoguibovich »</TD></TR><TR><TD CLASS="quote">I live In Peru (south america if you don´t know jajaja) I´ve been searchin for some information about my engine D16A9 but I haven´t found to much. This engine came here in the Civic Si 1.6 DOHC non- vtec. It´s a little extrange and hard to find information about it. Anyone who knows where to find? or, whta´s the equivalent in other engine code?</TD></TR></TABLE>
We didn't have that engine or its equivalent in the US. The DOHC ZC is the same engine from Japan and Europe. It's a very popular swap in the U.S.
And if anybody dares mention it, it is NOT the same as the 88-89 Integra motor.
Found in:
1988-1991 Civic/CRX/Concerto (UK/Europe)
1989-1996 Rover 216/416 GTI (UK/Europe)
1992-1995 Civic Si (Peruvian version)
1992-1995 Civic GTi
Displacement : 1590 cm3
Bore and Stroke : 75 mm X 90 mm
Compression : 9.5:1
Power : 130 hp @ 6800 rpm
Torque 108 ft-lb @ 5700 rpm
Valvetrain : DOHC
Fuel Control : OBD-0 MPFI
Found in:
1992-1995 Civic GTi
Compression : 9.5:1
Valvetrain : DOHC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
And if anybody dares mention it, it is NOT the same as the 88-89 Integra motor.</TD></TR></TABLE>
and you should add that only a small amount of parts are interchangeable between the dohc zc and the d16a1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayjay »</TD></TR><TR><TD CLASS="quote">
and you should add that only a small amount of parts are interchangeable between the dohc zc and the d16a1.</TD></TR></TABLE>\
This is true. OP, here's a link to a reliable parts list if you need to order parts from the U.S.
http://www.thezcr.com/forums/s...12262
classciv
24
Aug 14, 2005 09:12 AM
sicivicsniper
Apr 18, 2005 04:52 PM
