'95 Accord Starter Prob
Just want to do a check on this. I've got a starter problem and looking at the local junkyards one junkyard offers $75 for a starter the other offers $40. There a reason for this?
Also what can I expect to do when replacing the starter? (ie. taking out the radiator and **** like that?)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tlovaj »</TD></TR><TR><TD CLASS="quote">whats the easiest way to replace the starter?</TD></TR></TABLE>
disconnect the battery, if anti-theft radio make sure to have the code .. remove the main battery cable at starter 12 mm nut, unplug the starter solenoid wire, remove the 2 14 mm bolts that hold the starter in place, remove the starter ..there might be a bracket in the way held by a 10mm bolt on top of starter , you need to remove it as well ,,,,,,,,,,it is a fairly easy job
