Having trouble starting
Hello HT. I have a 1990 EF and it seems to not want to start a lot of the time. It seems to do this when the engine it warm, starts up cold just fine. The car is completely stock, I just bought it. I am getting a spark but I think it may not be getting fuel. Maybe a sensor or fuel pump? Sorry if this has been covered before, I just want to make sure that I buy the right part.
Sounds like your main relay is going out. It is located behind your coin pocket on your drivers side. Try to listen for a click before you start the car..... You can replace it or re-solder the joins inside the relay itself.
Also you can unbolt (sort of a pain to get to) and take off the relay cover. If there is brown residue on the motherboard (green), then it is going out. GL
Ok, reporting again.
I changed the main relay and I still am having the problem. It happens usually after I have driven the car recently, then let it set for a short while. I'm getting no check engine light. Another thing is, sometimes it will crank and just not start, but sometimes the engine just makes a grinding sound (think grinding gears) and nothing will turn.
can you hear the main relay click before you turn the car over??? Possibly the coil is goin out in your dizzy.. i have heard of ppl having problems once the car gets hot
uszcrx
24
Sep 9, 2006 01:05 PM
AgentJam
Aug 15, 2004 03:07 PM
serious
Sep 2, 2002 05:38 PM
