code 15 problems
I just swapped in a stock motor ( d16a6 ) in to my 90 HF and I am throwing code 15 ignition output. I have power going to the coil from the dizzy plug but no spark. I even tried a dizzy from my friends car but still no spark and still code 15 even after I cleared the code. All my fuses are good and so are my grounds. Thanks in advance for any help.
your problem is that you are trying to use the Si engine harness in the HF car which doesn't work beacuse the igniter (code 15) wire in the HF chassis is in the driver's side connection and the igniter wire in the Si engine harness is in the passenger side connector
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 »</TD></TR><TR><TD CLASS="quote">Were is that ignitor wire in the hf and were is it in the si ?</TD></TR></TABLE>read the above and look at the picture
