ls vtec bearings
i have heard that the thing with the ls motors was that the bottem end can't handle all the high reving like a gsr, type r, or si motors. is this true? i have a freind that is putting together a ls/vtec and i was wondering what type of bearings to use. by bearings i mean CRANK, MAIN and ROD bearings what type and for what motor do you get them from gsr, type r, si, or just use stock ls bearings.
use the factory bearings for the crank, rod mains. if its a ls block use ls bearings si use si bearings etc. also make sure you get all the codes figurred out correctly or ull spin one real quick.
he is building it pretty soon so ARP rod bolts and king race bearings is what he needs. i told him since he is going to rebuild it atleast put high compression pistons, cause he is going all motor i thought it would only help. what about the ARP head studs, should he see about those also? me personally vtec bottem end with vtec head is the only way to go.
