Kaixen HID Kits … High Quality HID Lighting Kits!
Old Aug 22, 2007 | 08:43 PM
autodoodad.com's Avatar
Default Kaixen HID Kits … High Quality HID Lighting Kits!
Kaixen HID Kits … High Quality HID kits with 1-year replacement warranty!
We also carry OEM D2C (sub for D2R & D2S) replacement HID bulbs for $89 per set in 5000K, 6000K, 6500K & 8500K. Email me at Sales@AutoDoodad.com so I can email you an online invoice.
Hello … Honda-Tech members,
I have KAIXEN HID Kits available for Honda-Tech members at a great price. These are one of the highest quality HID light kits you can buy, with one of the lowest defect rates in the industry.
Here we go with HID Course 101:
What is HID?
HID states for High Intensity Discharge. The light is emitted from an arc discharge between two closely spaced electrodes hermetically sealed inside a small quartz glass tubular envelope capsule. To operate, they require ballasts, which supply proper voltage and control current. The amount of light produced is greater than a standard halogen bulb, while consuming less power, and more closely approximating the color temperature of natural daylight.
3X brighter than any halogen bulbs. Typical halogen bulbs will give you between 500 to 1000 Lumens, while consuming 55 watts or more. HID on the other hand will give you 3200 Lumens (based on 4300K), while consuming only 35 watts. Halogen 1000 Lumen vs HID 3200 Lumen = HID at 3x the light output of halogen. The difference in light output is like day and night. The color temperature of HID lighting is a whiter light and more closely approximates the color temperature of natural daylight than does a halogen system, which appears yellowish in comparison.
HID bulbs last longer than halogen, almost 10 times longer. HID bulbs will last about 2500 hours. This means, it will last about 3 to 5 years of regular usage.
You have the option to get:
Pure White (5000K),
Crystal White with a hint of blue (6000K),
Crystal Purple (6500K),
Crystal Blue (8500K).
No after market HID kit nor HID retrofit kit is USA DOT certified. These lights are for show and off road use only. Unless your vehicle came from the factory with HID, they are not legal. It’s like a higher wattage bulb, or a muffler that is louder than the original, or wider tires that stick out past the mud flap, or tinted front door windows can be technically illegal, it's up to the user if they want to take the risk or not.
Kaixen brand key facts:
1. These are a 100% genuine Made in Korea brand.
2. Kaixen HID kits were first sold using Philips / Matshu****a ballasts and bulbs starting in 1999. Since then, Kaixen has received its own license as well as hiring several key engineers from Germany to develop its own high quality ballast and bulbs since 2002.
3. Kaixen is the only company other than Philips to develop the diamond-cut bulbs.
4. Kaixen is ISO 2001 registered, E13 certified, and KQA quality assurance certified.
5. All kits are made direct in the factory, and are not "rebased" as most Philips HID kits are made.
6. Fit and finish quality is second to none.
7. Quality comparable to, if not better than, OEM materials.
8. Comes with 1-year full replacement defect warranty handled in the USA.
9. Sold in over 55 countries, #2 selling HID kit in Europe & Australia after #1 OEM kit.
Competitive comparison:
1. Made in China & Taiwan products: Yes, they’re cheap, but are getting a good value for your money. Although "Made in China" products have improved in recent years, most of the HID manufacturers in China are poorly managed, use cheap labor causing more risk of product defects, use cheaper raw materials causing more risk of defects, and fit & finish is poor compared to other Korean, Japanese, or German brands. There's a reason why many of these kits (mostly sold on EBAY) are sold for around $130 to $200. It's because they cost that much less to build. Many times cutting corners to save money, in areas that shouldn't be cut like labor, materials and quality control.
2. OEM / Philips: Direct OEM replacement kits cost around $600 per one side (over $1000 for both sets). Therefore, many people go to the "next best thing", Philips. However, what most people don't know is that Philips does not make a variety of sizes. Philip's buyers like Audi do not use all variations of sizes. This is why many resellers "rebase" the Philips bulbs to make it fit into sizes that are not originally made from a Philips factory. There is a higher risk of product defect because of this modification. This is also another reason that many Philips kit's warranty is only valid from the reseller, and not from Philips head office.
In comparison, Kaixen manufactures all sizes and colors directly from their manufacturing facility in South Korea. There is no rebasing or modification done outside of the factory, and all warranties are offered directly from Kaixen.
Colors Available:
4000K (Yellow White),
5000K (Pure White),
6000K (Crystal White with a hint of blue),
6500K (Crystal Purple),
8500K (Crystal Blue).
Kelvin is the basic unit of thermodynamic temperature scale. Less Kelvins (K) has better Lumens or brightness. More Kelvins (K) has more color.
Included Parts in Kaixen HID Single Beam Kit:
HID Light Bulbs x 2ea
Ballast x 2ea
Connector x 2ea
Ballast Connector Cable x 2ea
Cable Tie, long x 2ea
Cable Tie, short x 2ea
20 Amp fuse x 2ea
Double Coated Adhesive Tape x 2ea
Owners Manual & Product Warranty x 1ea
Dual Beam Kits Additionally Include:
Controller x 2ea
Relay Kit x 2ea
Rubber Cover x 2ea
Installation: Kaixen kits are true "plug and play" kits with easy installation. The Kaixen owners manual includes written and pictured installation instructions.
Warranty: 1-year full replacement warranty against component defects. Warranty is handled by AutoDoodad here in the U.S.A. and backed by Kaixen! Replacement parts are strictly new and never any repaired or refurbished ballasts or bulbs.
Price: Single Beam Kits: $279 USD with free shipping within the U.S.
Dual Beam Kits: $359 USD with free shipping within the U.S.
We will ship to anywhere in the world (email for international shipping quote).
Payment options:
1) go to http://www.GoogleCheckout.com and send your payment to my Google account 'sales@AutoDoodad.com', or
2) send me your email address and I can send you an invoice, or
3) mail a cashiers check or money order and deduct $10 from the price.
4) also accept Paypal.
Delivery: In stock kit delivery time is about 3 business days. We normally ship via USPS Priority Mail. Other shipping methods are available upon request. International shipping rates vary by location. If you are not within the US, please contact us before placing order.
Feel free to email me at sales@autodoodad.com or PM me on this forum for details or questions.
******* http://www.AutoDoodad.com *******
Modified by autodoodad.com at 2:15 PM 8/25/2007
Modified by autodoodad.com at 2:18 PM 8/25/2007
Modified by autodoodad.com at 2:30 PM 8/25/2007
Modified by autodoodad.com at 11:21 PM 3/6/2008
Modified by autodoodad.com at 11:28 PM 3/6/2008
Old Aug 25, 2007 | 11:34 AM
Default Re: Kaixen HID Kits … High Quality HID Lighting Kits! (autodoodad.com)
Kaixen HID isn’t like conventional halogen lighting: there are no filaments to break or degrade. Yet Kaixen illuminates with three times the intensity of any halogen currently available, while burning far longer and consuming less power. Kaixen HID bulbs last ten times longer than halogen bulbs, up to 3,000 hours while consuming only 65% of the power used by halogen bulbs.
Old Sep 8, 2007 | 01:58 PM
jasontluong's Avatar
I thought all of the other high quality HID kits were made to do that.
Old Mar 6, 2008 | 08:23 PM
Available Kaixen colors:
Crystal Yellow----4000K (for fog lights) [extra cost]
Pure White-------5000K (pure white)
Crystal White----6000K (white with a slight hint of blue)
Crystal Purple---6500K (white with slight hint of purple)
Crystal Blue-----8500K (white with very blue)
Old Mar 7, 2008 | 02:09 AM
SpecialEdxl's Avatar
they do haha
Old Mar 8, 2008 | 05:48 AM
Yes, Most HID bulbs produce those same stats but please don't say "the other high quality kits" when talking about Kaixen. Let's see, who make a kit the quality of Kaixen... Sylvania or Philips? Opps, sorry they don't make kits only bulbs and other people repackage the bulbs. Kaixen makes their own bulbs and electronics and that is why we are a head above all the others.
Old Mar 8, 2008 | 07:12 PM
Importn2oRacer's Avatar
in my opinion all these pnp kits are the same
itrhatch2
Mid-Atlantic (Sales)
Oct 26, 2008 05:22 PM
Au2Tek
Jun 25, 2007 11:44 AM
EJ8 GSR-T
Jan 23, 2007 10:31 PM
