2nd clutch pressure switch failure
can ne help me out in locating the 2nd clutch pressure switches on a 98 honda accord 4 banger automatic. Which one do i need to swap out the front or the rear one....or do i need to do both...i guess i could do it one by one and see if the code goes away but i would rather limit the trips to the dealer and get it right the first try
Modified by N1civicSi at 6:04 AM 8/23/2007
thanks man.....i pulled the code and it says that the 2nd clutch pressure switch might have failed....there are two one in the front and one in the back....not sure which one i need to change...ne one else have this problem before???
ZamboniDude
Acura TSX
Jan 20, 2019 03:40 PM
10w30
Aug 1, 2018 07:04 AM
Bigskyguy
Nov 20, 2017 03:54 PM
