will these cams work
Old Aug 22, 2007 | 03:24 PM
b18 hatch mike's Avatar
Default will these cams work
PRIME LOBE
CENTERLINE - 16.05 BTDC
INTAKE: Duration: 237.17 @ 0.060 INCHES Lift: 0.5583 INCHES
EXHAUST: Duration: 256 @ 0.050 INCHES Lift: 0.494 INCHES
will they work on stock b16a valve train
Old Aug 22, 2007 | 03:28 PM
SkankyEJ7's Avatar
Default Re: will these cams work (b18 hatch mike)
14.1808 mm intake
12.5476 mm exhaust
so not no but hell naw would max out stock vavlesprings, like dont b16a vavlespring bind around 12.5 or something
Old Aug 22, 2007 | 03:32 PM
DonF's Avatar
Sure, those lift numbers are like Skunk Pro4's, BC stg.7's, Jun 5's and RM 28x's. Get good LMA's not used ones.
Old Aug 22, 2007 | 03:35 PM
Rocket's Avatar
Default Re: will these cams work (DonF)
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Sure, those lift numbers are like Skunk Pro4's, BC stg.7's, Jun 5's and RM 28x's. Get good LMA's not used ones.</TD></TR></TABLE>
are you saying sure those cams will work with stock b16a valvetrain?
Old Aug 22, 2007 | 03:39 PM
Rocket's Avatar
Default Re: will these cams work (SkankyEJ7)
Here are some "good" numbers for hot street. 260/255 duration @ 0.050" in/ex. 12mm max lift and 101/107 centres in/ex.
Old Aug 22, 2007 | 03:41 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">
are you saying sure those cams will work with stock b16a valvetrain?</TD></TR></TABLE> Just as well as the above listed cams.
Old Aug 22, 2007 | 03:54 PM
SkankyEJ7's Avatar
oh i was about to say that stock b16a may not like 14.18mm of lift, and prolly wouldn't agree with 12.5mm on the exhaust side very long
Old Aug 22, 2007 | 04:02 PM
so i take that as a no they will not work and if no what about stock ctr cams
Old Aug 22, 2007 | 04:25 PM
bump
22psicrx
Jul 26, 2007 05:16 PM
DC5ftmfw
10
May 23, 2007 12:33 PM
mca_gsr
Jun 5, 2006 02:02 AM
hondaboyB18C1
19
Dec 16, 2003 06:25 PM
