EG Fog Light Switch with a Defroster Harness attached HELP ON WIRE CODING!
Old Aug 22, 2007 | 02:06 PM
92EG8's Avatar
Default EG Fog Light Switch with a Defroster Harness attached HELP ON WIRE CODING!
Ok i finally got a fog light switch for my EG. I got the wiring harness from the back of the defroster switch since it fits right into the fog light switch "5 wires i think" I made my OWN harness for my fogs....as of now I have it to a switch of advanced auto parts... I wanna put the two wires ( + and - ) to the fog light switch. Which of the 5 wires need to be connected to my positive and negative of my harness and which one is the ground one to light up the switch?
Cliffs: Need Diagram to show which wires is positive to the fog light switch and which one is negative and which is the ground for the little green light
Old Aug 22, 2007 | 02:34 PM
92EG8's Avatar
bump also whats the bulb size on the EG fogs? H3?
Old Aug 22, 2007 | 03:52 PM
JSPECSIR's Avatar
Default Re: (92EG8)
yes the bulbs are h3. you will also need a relay if you dont have one as that is all the oem switch turns on is a relay. the relay in turn cuts on the foglights.
Old Aug 22, 2007 | 04:02 PM
92EG8's Avatar
hmm can you explain a little more? how can i make this relay?
Old Aug 23, 2007 | 03:45 PM
92EG8's Avatar
bump
Old Aug 28, 2007 | 01:56 PM
92EG8's Avatar
bump
Old Aug 28, 2007 | 05:25 PM
92EG8's Avatar
help anyone
Old Aug 28, 2007 | 05:56 PM
JSPECSIR's Avatar
Default Re: (92EG8)
take this to audio security forum. some of those guys will be able to make you a diagram and have pics of relays.
evildragonrsx
Dec 13, 2011 09:41 AM
SBlimeDC2
Oct 7, 2007 07:34 PM
egblack94
32
Jul 26, 2007 03:24 PM
