JDM Brakes
Has anyone ever installed the JDM CRX brakes on their USDM car. If so what tie rod ends did you use. I don't have the JDM ones and wondered if the 90-93 Integra's will work. Hope to hear from someone. thanks.
if you're talking about the SiR brakes, the fronts are the same as the 90-91 ex sedan & the rear are the same as the usdm crx si i believe.
for the front brakes, you need the knuckles from the 90-91 ex sedan & for the rear you need crx si or 90-93 intergra trailing arms. you shouldn't have to replace your tie rods at all i don't think.
eric
eric
civtrx
Mar 19, 2008 06:40 PM
