ac has gone crazy HELP
Old Aug 22, 2007 | 12:49 PM
Civic Racer X 7's Avatar
Default ac has gone crazy HELP
it used to do this way less but its become really bad
the compressor will kick on and it will blow cold air
every 5-10 misn it will cut off (normal driving)
for about 2 mins then come back on for 5 to 10 then kick off
when the compressor kicks off the air is hot and mucky
whats goin on?
on cool nights it doesnt do ti nearly as bad
mainly in HOT day weather and sometimes at higher RPM's
is it my compressor?
or comp clutch?
or some relay that controls it has malfuncted
Old Aug 22, 2007 | 12:58 PM
crazyguy's Avatar
Default Re: ac has gone crazy HELP (Civic Racer X 7)
if you compressor engages and the condensor fan works.that means time to recharge the ac system and maybe check for the leak n make sure compressor does not seize up.also if your ac dryer/ receiver is old, u might want to replace it too
Old Aug 22, 2007 | 01:01 PM
J.D.M's Avatar
Same problem I've been experiencing as of late. When it's works, it's COLD, when it doesn't... that hot and mucky feeling e.e Should definitely get it checked out as I am
Old Aug 22, 2007 | 01:03 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Racer X 7 &raquo;</TD></TR><TR><TD CLASS="quote">it used to do this way less but its become really bad
whats goin on?
or comp clutch?
are you sure it is your compressor.
to get cold air from your a/c, air has to flow through your condensor. so if your fan is bad, or the relay is intermitting, this will be the cause of the hot air. but then when you drive you notice it cooling down, that is the air flowing through the condensor.
i would check the fan and the relay to see if they are fully operational before replacing a expensive part like the condensor.
Old Aug 22, 2007 | 04:53 PM
yes im sure because I can FEEL it disengage and then engage after a few mins and the idle changes if Im at idle
its def the compreesor turning off and on
Old Aug 23, 2007 | 08:42 AM
philosofy1's Avatar
Default Re: (Civic Racer X 7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Racer X 7 &raquo;</TD></TR><TR><TD CLASS="quote">yes im sure because I can FEEL it disengage and then engage after a few mins and the idle changes if Im at idle
its def the compreesor turning off and on</TD></TR></TABLE>
the idle changes when the fan turns on too.
E30LS1
Honda Civic (2001 - 2005)
Jul 9, 2014 09:40 AM
xxjokoxx
Aug 23, 2010 12:51 AM
lakerschamp2000
19
Apr 24, 2009 12:37 PM
