New Vs. Old sway bar
I was wondering if sway bars can go bad? I'm looking to buy a used 03 type R sway bar and I'm wondering if it'll be as good as a brand new one? thanks!
I just want to make sure so I don't make an offer to high
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">The way they curve pretty much elimates cracking.
I suggest the Tanabe. 28mm
not good to have such a big front bar. give alot of understeer.
</TD></TR></TABLE>not good to have such a big front bar. give alot of understeer.
The front OEM is bigger than the rear OEM. The front has to stop a lot more weight from rolling. With an upgraded rear (22mm), understeer is back to stock feeling (with a lot less roll). And that's what an alignment is for anyways...
I already bought the CTR one and this is how it goes....
- civic ex 01-02 = 25.4mm (this is the one you want)
- civic ex 03-05 = 16mm
- ITR front sway will not fit unless you have the ITR control arms, b/c the ITR's are wider then our USDM Type S's
- CTR's are the same width as our USDM Type S's so the Front sway bar is interchangeable with our cars
So if you need to buy a front sway bar for your RH or ITR header and you have the USDM control arms, buy the 01-02 civic ex or the CTR front sway bar
and if you're baller and have the aluminum ITR control arms then you can put the ITR front sway bar on
/Thread
/Thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5Aspec’d »</TD></TR><TR><TD CLASS="quote">that is a rear sway bar </TD></TR></TABLE>
That is a front swaybar (look at race header)
That is a front swaybar (look at race header)</TD></TR></TABLE>
click one the link he posted, its a rear sway bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5ITR329 »</TD></TR><TR><TD CLASS="quote">why would you buy a used one when a new one is like 100
http://yhst-1408381693991.stor....html</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5ITR329 »</TD></TR><TR><TD CLASS="quote">why would you buy a used one when a new one is like 100http://yhst-1408381693991.stor....html</TD></TR></TABLE>
In the pic thought thats a front sway bar. U can see the axel behind it on the right hand side of the picture.
</TD></TR></TABLE>In the pic thought thats a front sway bar. U can see the axel behind it on the right hand side of the picture.
