Temp Gauge Bottoming Out
Old Aug 22, 2007 | 11:38 AM
nz_mike's Avatar
Default Temp Gauge Bottoming Out
Hi,
I have recently noticed my temperature gauge bottoming right out during flat our downhill highway driving. The temperature is normal in city driving and uphill highway driving.
Would this be caused by the mechanical thermostat not closing properly? To what extent is the thermostat supposed to regulate engine temperature when drivng?
Can running at such a low temp damage the engine?
Cheers
Old Aug 22, 2007 | 12:04 PM
Volcom's Avatar
Default Re: Temp Gauge Bottoming Out (nz_mike)
Sounds like the therostat! My Integra did the same thing years ago. It was during winter and I didn't have any heat going downhill
Old Aug 22, 2007 | 12:36 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Your problem may lie with a faulty guage sender (the one wire sender connected to engine block that goes to the dashboard temperature guage), a loose connector, or a faulty temperature guage.
If your car is already warmed up and the needle goes down (needle even bottoming out) during downhill driving, most likely your car is not running colder.
Old Aug 24, 2007 | 02:54 PM
nz_mike's Avatar
Default Re: Temp Gauge Bottoming Out (tech8)
The fact that it occurs only when the engine is not heavily loaded and there is a very high airflow rate through the radiator (highway)) would suggest that it is unlikely to be an intermittent fault. I will replace the thermo and c what happens
213374U
Jul 31, 2007 05:49 PM
electric-boost
Dec 11, 2006 08:37 PM
jman
Oct 12, 2002 08:20 PM
Cosworth
Jun 15, 2001 12:04 PM
