San Diego Timing Belt Mechanic?
Old Aug 22, 2007 | 10:25 AM
mullenium's Avatar
Default San Diego Timing Belt Mechanic?
My 02 Accord SE has yet to have the timing and tension belts changed, its currently got like 113k on the clock so im thinking i need to get this done asap lol.
any good mechanics in san diego that wont charge me an *** load.
so far Ive been quoted 700-750 from mechanic #1 which is the tensioners, t-belt, labor, parts etc.. water pump not included ($50-70) (half a day's work)
and $800-ish from mechanic #2 for everything that needs to be replaced (he said some stuff might still be good and wont need replacing) (full day's work)
?? any ideas?
thanks guys!
Old Aug 22, 2007 | 10:28 AM
Bruce Banner's Avatar
Default Re: San Diego Timing Belt Mechanic? (mullenium)
Forget those people, they are ripping u off.
Old Aug 22, 2007 | 11:40 AM
mullenium's Avatar
ok i got a quote for 400-450 for everything..not including water pump, he says that if its not leaking dont need to mess with it.
i think ima go with this guy, 400-450 seems reasonable
Old Aug 22, 2007 | 11:59 AM
Default Re: (mullenium)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullenium &raquo;</TD></TR><TR><TD CLASS="quote">ok i got a quote for 400-450 for everything..not including water pump, he says that if its not leaking dont need to mess with it.
i think ima go with this guy, 400-450 seems reasonable</TD></TR></TABLE>
That;s a reasonable rate, but the pump should be done too
Old Aug 22, 2007 | 12:05 PM
mullenium's Avatar
he said 80 for aftermarket waterpump
175 for oem stock
Old Aug 22, 2007 | 12:44 PM
F23Coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullenium &raquo;</TD></TR><TR><TD CLASS="quote">he said 80 for aftermarket waterpump
175 for oem stock</TD></TR></TABLE>
$175 for oem water pump? Ok, something's smelling fishy there. They don't cost more than $100, usually less than $50 for Accords, though not sure for the V6 models. My trusty mechanic usually charges $300 labor and the parts that I buy on my own come out to $200 or so.
Old Aug 30, 2007 | 12:12 PM
Default Re: (F23Coupe)
You could buy the parts and pay the guy labor only.
That way if he marked up up higher on parts, you can call him out on it when he tries to move some $$$ to labor later.
Old Aug 30, 2007 | 03:25 PM
Honda-Master's Avatar
woooooo,,,
4 cyl water pump from Honda dealer $ 68
6 cyl water pump from dealer $ 124
dohcredsol
Mar 25, 2008 10:13 PM
Kryptonite
Jul 5, 2005 10:08 PM
703_Sleeper
Feb 12, 2005 06:04 AM
CRX Si
15
Feb 9, 2005 03:50 PM
Calean007
Nov 27, 2004 05:13 AM
