compression test with skunk2 pro series cams
Old Aug 22, 2007 | 10:11 AM
20vsleeper's Avatar
Default compression test with skunk2 pro series cams
Hi guys,
Just bought a ITR that comes with a stock bottom end... skunk2pro series cams and valvetrain... we did a compression test on a warm motor
175 across the board...????
whats up with that. My question is do the cams effect the compression test?
big cams-lower test?
please advise
Thanks
Old Aug 22, 2007 | 10:15 AM
JjuuN R's Avatar
Not at all, I'd get in contact with the seller...
Old Aug 22, 2007 | 10:22 AM
20vsleeper's Avatar
Default Re: (JjuuN R)
what should the compression be on a stock usdm itr motor?
Old Aug 22, 2007 | 10:25 AM
Dave_B's Avatar
My question is, why Pro series cams in a stock motor?
Old Aug 22, 2007 | 10:30 AM
JjuuN R's Avatar
Default Re: (Dave_B)
240-245psi across the board for me... Did one Monday night.
Old Aug 22, 2007 | 10:43 AM
andyt's Avatar
Default Re: (20vsleeper)
It will also depend on the accuracy of your gauge.
At least they were all the same...instead of one being alot lower.
I would do a leakdown test.
Old Aug 22, 2007 | 12:23 PM
-Infinity-'s Avatar
Default Re: compression test with skunk2 pro series cams (20vsleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20vsleeper &raquo;</TD></TR><TR><TD CLASS="quote"> My question is do the cams effect the compression test?
please advise
Thanks</TD></TR></TABLE>
If the cams are not dialed in, you could lose compression. There is the chance that intake and exhaust valves are over laping.
Old Aug 22, 2007 | 06:36 PM
stumpyf4's Avatar
Was the throttle open all the way when you did the compression test?
Old Aug 23, 2007 | 05:14 AM
itrdave's Avatar
Cams and timing will most certainly affect compression results... This is why VTEC engines have such enormous compression (on small cam) compared with mortal engines.
Old Aug 23, 2007 | 05:24 AM
sp00led's Avatar
175 is what I had on my 83mm b18c1 with 9:1 compression.
Old Aug 23, 2007 | 06:27 AM
20vsleeper's Avatar
Default Re: compression test with skunk2 pro series cams (sp00led)
Went back to the shop last nite... the throttle was not wide open when we did the test....
we did a leakdown on the motor and it came out excellent.. dont remember the exact % but it was in the "white" on all cylinders!
dbiker207
Nov 26, 2006 07:10 AM
b16a27
Jun 13, 2005 12:20 PM
Mr.Integra
Apr 28, 2004 05:47 AM
bxsi
Apr 2, 2004 05:42 AM
bxsi
Apr 1, 2004 09:20 PM
