H22 swap Idling issues
I've looked all thru the forums, for any resolution for my problem, it seems a lot of people have had the problem I am having. But there is no affirmed solution to it. I have a 96 accord with an H22 swap, the problem is that coming to a stop, I push the clutch in and put it in neutral, the RPMs will drop very low, or maye even cause the car to stall, or I could be sitting at a light waiting for it to turn green and I push the pedal, and it'll stall (before I put int in grea)I've read that it could be things such as IACV, FITV, or vacuum lines. well I replaced the fitv, and cleaned my IACV. I've taken it to many shops around town to get different answers such as my transmission, throwout bearing, pressure plate (none of which it is b/c I have a new tranny in) oil pump. oh and I have a dent in my oil pan, could this be he cause of the problem? regardless I am going to fix it...I'd just like to have a somewhat definite answer to my problem before I spend money on it. Thanks for any help that can be provided
open your throttle little bit so it won't idle too low. This same problem happened to me before. I just opened the throttle little bit more. It idles around 850 to 950 but it doesn't die anymore.
