Smsp or Toda
Old Jun 13, 2002 | 01:50 PM
brownman72000's Avatar
Default Smsp or Toda
Which header would be better for the ITR? The Toda or the SMTP? The great dyno test showed that both gave 14 hp and about 7 lbs/t. I currently have the AEM intake and also plan on getting the Thermal axel back exhaust as I hear it is one of the better ones. Also, what are the price differences between the two headers? Thanks!
Old Jun 13, 2002 | 01:53 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Smsp or Toda (brownman72000)
SEARCH!!
Fuggin' n00bs
https://honda-tech.com/zerothread?id=206502
[Modified by Splat, 5:54 PM 6/13/2002]
Old Jun 13, 2002 | 01:54 PM
Austin's Avatar
Whichever works best for your planned state of modifications...you can tell which header I have
Cosworth's Avatar
There is a guy selling his used Toda header for $800 in the classifieds... which I think is a good price.
Old Jun 13, 2002 | 01:55 PM
Reid's Avatar
Global Moderator
Ignore that Splat guy, he doesn't even own an ITR, what does he know?
For us ITR owners, it's nothing but the best. The Chikara header made the most power in the Great Header Test but it was removed from the results because TODA threatened to sue the people who ran the test.
Chikara
Also ditch the AEM, the Ractive ram air intake makes more power, DYNO PROVEN.
Old Jun 13, 2002 | 01:58 PM
B2FiNiTY's Avatar
Default Re: Smsp or Toda (Reid)
I agree with Reid on weed.
Old Jun 13, 2002 | 02:00 PM
what was the result of the chikara and how much does that header go for?
Old Jun 13, 2002 | 02:01 PM
CPR's Avatar
CPR
How about that Deez Nutz In Your Mouth header. It's on back order though.
EDIT - Sorry guy. Had a boring day at work and I needed to vent. Nothing personal.
[Modified by CPR, 6:03 PM 6/13/2002]
BlueR's Avatar
put on the flame suit NOW!!!!!
Old Jun 13, 2002 | 02:02 PM
B2FiNiTY's Avatar
Default Re: Smsp or Toda (BlueR)
Nothing can save you but the search function...use it wisely.
Old Jun 13, 2002 | 02:03 PM
Reid's Avatar
Global Moderator
Not sure, but Summit Racing carries it. Jegs might also.
It makes lots of power on the low end and the top end is just mad crazy. I'm still salty that I got my TODA header after that test came out. This TODA is overpriced and still can't outperform the Chikara.
Old Jun 13, 2002 | 02:04 PM
B2FiNiTY's Avatar
What's the collector size? 1.75? Smaller the better. The smaller the collector is, the faster the air flows thus like a ram air effect but for the exhaust.
Splat's Avatar
Damn, y'all are ruthless! I've been R-less for two hours and already I get ****
Old Jun 13, 2002 | 02:05 PM
CPR's Avatar
CPR
Chikara.
Isn't that a singer?
Back in Black's Avatar
Rather OG
Default Re: Smsp or Toda (Splat)
You are what you get...traitor!
Jason-
who's just fuggin wit da Splatman
Old Jun 13, 2002 | 02:06 PM
gsr98vtec's Avatar
we've been through this countless times, search or just buy smsp for 2.0L or a toda for a 1.8L
Reid's Avatar
Global Moderator
Default Re: Smsp or Toda (B2FiNiTY)
You clearly know nothing. It's not ram air, but a Ventuli effect.
I wish you would stop trying to mislead him with your false information.
R-Rated's Avatar
Default Re: Smsp or Toda (CPR)
Arospeed!
Old Jun 13, 2002 | 02:07 PM
B2FiNiTY's Avatar
My bad my bad... What about the exhaust? Aren't bottle necks better since it creates more back pressure thus helping out low end tq?
Old Jun 13, 2002 | 02:09 PM
BlueR's Avatar
why you all gotta start this **** when i leave work
been cruising the R forum the whole day and BORING....
Old Jun 13, 2002 | 02:10 PM
CPR's Avatar
CPR
Yes, yes it is. Bottlenecks in exhausts serve the same purpose as beer bottlenecks. Slow flow means less spills
Reid's Avatar
Global Moderator
No, you see ideally you'd want a 2" collector (since no one makes a 2" version, 2 1/4" will work) to create the Ventuli effect and speed up air velocity. Ok so once your exhaust goes through the collector it's traveling at a high rate of speed. So the exhaust needs to be as big as possible (usually 3" is the biggest that can be used, but the bigger the better) to let all the exhaust gas maintain it's high velocity.
Old Jun 13, 2002 | 02:12 PM
Reid's Avatar
Global Moderator
You guys really need to learn what you're talking about.
Seems the internet is full of idiots and people trying to mislead you nowadays.
B2FiNiTY's Avatar
Ooooooooooooooohhhhhhhhhhhhhhhh I get it!
CPR's Avatar
CPR
Reid, your knowledge amazes me. Thanks for the tips!
