70mm Throttle body on my B20Vtec build question???
I need help I had my motor started and I dont know what short ram intake to run because my old intake was made for the stock B16 throttle body. But now it doesnt fit with the 70mm throttle body I'm running ... Any suggestion and maybe you guys can point me in the right direction... Would like to run a CAI instead of a short ram
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations »</TD></TR><TR><TD CLASS="quote">p/u a 3 inch one</TD></TR></TABLE>
where ???
where ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc »</TD></TR><TR><TD CLASS="quote">password whale dick. Made more power on my b20 than the AEM cai</TD></TR></TABLE>
whats your setup ???
b20 84.5mm sleeved 12.5:1 compression
BC spec 4 cams
rods and all that good stuff.
At the time I was running a stock IM and TB.
BC spec 4 cams
man same setup except ... running Skunk 2 manifold, hytech header copies, 70mm throttle body ... but I havent tune the hondata s200 ... need a good intake before hitting the dyno next week at church automotive....
Im telling you go with the whale dick it makes good power. I worked at a shop and it always made good power with the cars we tuned.
Probally lose power. Not only will you be sucking in hot air, but most intakes accelerate the air as it passes through. It may not speed up much, but even a little helps.
