stroker kits??
lots of cash, and if you dont invest in some headwork, bomb header of some sort, nice cams that will work with the setup it will never reach its full potential. Go research about turbos and put together a kit, it will stomp n/a strokers, well most of em. lol
I personally dont even know how they make a stroker kit for b series, at least a b18 when I had my head off there was no deck height what so ever with piston all the way up so a stoker kit would actully put the piston in the combustion chamber a little bit. not good for interferince motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 »</TD></TR><TR><TD CLASS="quote">I personally dont even know how they make a stroker kit for b series, at least a b18 when I had my head off there was no deck height what so ever with piston all the way up so a stoker kit would actully put the piston in the combustion chamber a little bit. not good for interferince motor.</TD></TR></TABLE>
different length rods and pistons with relocated pins
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">You're money would be better spent in another motor or FI.
Spoon kits run ~$2000-3000
and are only available for b16b's. you basically turn it into a b18c5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
and are only available for b16b's. you basically turn it into a b18c5.</TD></TR></TABLE>
Exactly.
For the money of the spoon kit you could BUY a b18c5
Exactly.
Wow, I didn't know that.
If you spend 3k on spoon parts to turn your CTR into an ITR then you're an idiot.
actually they have the kit for b16a's primarily before the b16b's were even made..TODA brand
different length rods and pistons with relocated pins</TD></TR></TABLE>
I cant say for sure but I am pretty sure that the crank rod jornuals are spread furthor out but regardless how they do it, it still causes the same thing piston goes down furthor and goes up more. thats why I said I dont even know how they can cause when you take the head off a c1 the piston already comes to the very top of the block and any more would push it into the combustion chamber. but I dont build that **** so I dont know. all I know is theroy and how it works.
96CivicBoostCoupe
Jun 28, 2005 08:10 PM
Kidnkorner
28
Jan 12, 2004 03:39 PM
