who has an base rsx and whats the most hp you got out of it
Old Aug 21, 2007 | 08:23 PM
MesicanRSX04's Avatar
Default who has an base rsx and whats the most hp you got out of it
because i want to start makin mine faster but i know they wont get as fast as a type s but i want to make it get the most hp out of it
Old Aug 21, 2007 | 08:40 PM
posHonda's Avatar
base models have potential. if i were to FULLY build an rsx, it would be a base model. save for the turbo and youll blow away n/a rsx-s all day.
Old Aug 21, 2007 | 11:16 PM
thrty8street's Avatar
Default Re: who has an base rsx and whats the most hp you got out of it (MesicanRSX04)
get forced induction, either supercharger or turbo and get kpro.
Old Aug 22, 2007 | 01:50 AM
Aco512's Avatar
yeah that
a fully bolt-on base may hold its own against a STOCK type-s
but boosting it will surpass a n/a type-s
Old Aug 22, 2007 | 11:12 AM
kwicksilverdc5's Avatar
Default Re: (Aco512)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aco512 &raquo;</TD></TR><TR><TD CLASS="quote">yeah that
X2 N/a Would almost be a waste of money. I'd say save up and do it right.
Old Aug 22, 2007 | 12:23 PM
integra_type-S's Avatar
i have both a type-s and a base model rsx as well i have a v2 intake, dcrh, and full 5zigen catback and recently i raced it w/my type s and it pulled on it not much but a prety decent amount but type-s still manages to pull once vtec kicks in
Old Aug 22, 2007 | 12:56 PM
WhiteOnRice's Avatar
Forced induction
Old Aug 22, 2007 | 08:10 PM
dc5typearr's Avatar
Base rsx's can make very good numbers boosted, and they can make some pretty decent numbers n/a, a base with bolt on's, kpro, and stage 2 cams can make a solid 200 whp
Old Aug 22, 2007 | 11:30 PM
Aco512's Avatar
that's a lot of mods just to hit 200whp
all estimates:
i/rh/e =1000
k-pro =1000
stg2 cams = 800-1000? idk
thats near 3 grand
another grand (or 2) will get you a turbo set-up thats pushing near 260whp
from there on, skies the limit
Old Aug 22, 2007 | 11:52 PM
KOREAN's Avatar
boost.
I made 220whp at 6.5psi.
Old Aug 22, 2007 | 11:54 PM
Aco512's Avatar
^ he's a good example
i'm sure you can raise up the psi
Old Aug 23, 2007 | 07:15 AM
im thinking about getting this intake called carbon kevlar chamber it gets u 18.1 hp jus with that and no other mods its on passwordjdm.com but ive been lookin at turbos and everything but still cant find one so where would be a good site to look?
Old Aug 23, 2007 | 10:11 AM
T_Virus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MesicanRSX04 &raquo;</TD></TR><TR><TD CLASS="quote">im thinking about getting this intake called carbon kevlar chamber it gets u 18.1 hp jus with that and no other mods its on passwordjdm.com but ive been lookin at turbos and everything but still cant find one so where would be a good site to look?</TD></TR></TABLE>
Oh man....don't start with that 18.1 thing...your going to have to either turbo or SC just like what everyone said...
Old Aug 23, 2007 | 10:39 AM
p nut's Avatar
You can probably get that bundled together with "The Tornado."
Personally, I would not waste money on bolt-on's for a base RSX. If you want performance, boost it or sell it and get an RSX-S.
Old Aug 23, 2007 | 10:41 AM
Default Re: who has an base rsx and whats the most hp you got out of it (p nut)
would it be a bad thing if i have other mods and the sc or will jus the sc do it?
xcivic1.7x's Avatar
Default Re: who has an base rsx and whats the most hp you got out of it (T_Virus)
actually im buildin a k20a3 for my em2 and if you put stock type s cams in it and stock type s pistons you will have the exact same motor. the only thing that is diff between the two is the compression ration of the pistons and that there is no vtec lobes on the exhaust cam in the a3 as in the a2 there are lobes on the exhaust cam. so there spend like 500 on some stock cams and pistons and youll be ready to go.
Old Aug 23, 2007 | 04:07 PM
posHonda's Avatar
Default Re: who has an base rsx and whats the most hp you got out of it (xcivic1.7x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcivic1.7x &raquo;</TD></TR><TR><TD CLASS="quote">actually im buildin a k20a3 for my em2 and if you put stock type s cams in it and stock type s pistons you will have the exact same motor. the only thing that is diff between the two is the compression ration of the pistons and that there is no vtec lobes on the exhaust cam in the a3 as in the a2 there are lobes on the exhaust cam. so there spend like 500 on some stock cams and pistons and youll be ready to go.</TD></TR></TABLE>
is this is true im getting myself a base model. i would think the valvetrain between the S and base would be different too.
Old Aug 23, 2007 | 06:22 PM
where would you buy the rsx-s stock cams and pistons??
Old Aug 23, 2007 | 08:13 PM
risktypeS's Avatar
Don't listen to this stupid idiot.. it takes more then just getting some cams and pistons to making an A3 to become an A2. You'd be a fu|&lt;ing idiot if you follow this dumbass.
the k20a2 is COMPLETELY different then the k20a3
trying to take a k20a3 into a k20a2.. you might as well buy a k20a2 or just fully build your A3.
Old Aug 24, 2007 | 08:33 AM
T_Virus's Avatar
Default Re: who has an base rsx and whats the most hp you got out of it (risktypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS &raquo;</TD></TR><TR><TD CLASS="quote">
trying to take a k20a3 into a k20a2.. you might as well buy a k20a2 or just fully build your A3.</TD></TR></TABLE>
I agree...
Old Aug 24, 2007 | 09:37 AM
im jus gonna build up my rsx instead of doing all this stuff its more safe than risking messing up my engine but if i was to get a k20a2 how much would run for?
dtao819
10
Sep 22, 2008 05:31 AM
RicerGook
14
May 22, 2006 11:59 PM
fjt
May 4, 2005 05:31 PM
Sephiroth
23
Apr 20, 2005 03:33 AM
aCuRaLsTuRbO
38
Jul 18, 2002 01:23 PM
