Holy crap, I am experiencing an ELECTRICAL NITEMARE
Old Aug 21, 2007 | 08:22 PM
OEM Man's Avatar
Default Holy crap, I am experiencing an ELECTRICAL NITEMARE
I was fixing my alarm hood pin switch and interior piezo siren today. After doing that, I reconnected my battery and bam I discovered that there's a million things not working.
The dome light does light up anymore when the doors open. I even manually pressed in and out the factory door pins. If I switch the dome light switch to the ON position, it would light up, but when switched to the DOOR position, it's completely dead.
Now when I arm my car, it doesn't lock and unlock the doors anymore.
The remote trunk pop stopped working.
The secondary alarm sirens stopped sounding.
Usually whenever my alarm fails me, I can use the OEM Honda remote transmitter to lock and unlock the door. I just tried it, and it does not work anymore.
I think there might be a blown fuse somewhere, because a whole bunch of stuff stopped working at once. Is there a Honda factory fuse that controls the dome light door open indicator?
Any guess as to what may be wrong?
Old Aug 21, 2007 | 08:36 PM
xXSilentScreamXx's Avatar
Default Re: Holy crap, I am experiencing an ELECTRICAL NITEMARE (OEM Man)
wire the car up like it was when it was working and then diagnose your problem
reverse engineer ...kinda
Old Aug 21, 2007 | 08:41 PM
john666's Avatar
put it back to how it was before..
just hooking up a hood pin switch and a siren shouldnt do anything. but im guessing you wired it incorrectly someplace...
Old Aug 21, 2007 | 10:56 PM
turbo-2nr's Avatar
the stock keyless entry and the dome light are controled off of the radio what year and what kind of car is it
Old Oct 19, 2007 | 03:27 AM
spnej1's Avatar
Default Re: Holy crap, I am experiencing an ELECTRICAL NITEMARE (turbo-2nr)
1993 EX coupe
I didn't do anything to the wiring at all. All I did was remove the electrical tape wrapped around all the wires. When it was on, I would move the wires with my hand and get a signal for the electrical sometimes.
Now that the covering is off, nothing. No electrical to the fuel pump relay, no radio, no CEL, no nothing.
I'm about to just buy a multimeter and start checking continuity.
TUR3Ovtec
33
Aug 27, 2011 08:27 PM
TravisCadello
May 10, 2009 05:34 PM
H9Omega
Sep 9, 2007 02:38 PM
OEM Man
Audio / Security / Video
Aug 22, 2007 06:21 AM
AznJammyJam
Oct 7, 2004 01:51 AM
