D16Y8 Intake Manifold On D16Y7 motor
Old Aug 21, 2007 | 08:09 PM
bowdown201's Avatar
Default D16Y8 Intake Manifold On D16Y7 motor
I plan on puttin this IM on my car because i plan on turboing it and it wont fit the top mount Intake manifiold or whatever you call it on the Y7. What all would i need to do this. i also plan on getting the y8 head too so..any suggestions would be great
Old Aug 21, 2007 | 08:27 PM
Luserkid's Avatar
Default Re: D16Y8 Intake Manifold On D16Y7 motor (bowdown201)
You need an auto y8 intake manifold with all the trimmings.
Old Aug 21, 2007 | 08:28 PM
jonathan13's Avatar
Default Re: D16Y8 Intake Manifold On D16Y7 motor (Luserkid)
i also plan on doing this for the same reason. why would he need an auto intake mani instead of manual?
Old Aug 21, 2007 | 08:50 PM
Syndacate's Avatar
Default Re: D16Y8 Intake Manifold On D16Y7 motor (jonathan13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonathan13 &raquo;</TD></TR><TR><TD CLASS="quote">i also plan on doing this for the same reason. why would he need an auto intake mani instead of manual?</TD></TR></TABLE>
You don't need to use the intake mani off an automatic, it just makes things easier.
The automatic Y8 has the same IACV to TB setup as the Y7, which makes it easier. With a manual Y8 mani you have to block the IACV opening on the back and use the throttle butterfly/rotor/spring off your Y7 TB (into your Y8 TB)
Old Aug 21, 2007 | 08:51 PM
jonathan13's Avatar
Default Re: D16Y8 Intake Manifold On D16Y7 motor (Syndacate)
ah ok. thanks once again for the helpful information man!
Old Sep 20, 2007 | 05:24 AM
JimDCXC's Avatar
what is a good way to block IACV opening?
Old Sep 20, 2007 | 06:23 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: D16Y8 Intake Manifold On D16Y7 motor (JimDCXC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimDCXC &raquo;</TD></TR><TR><TD CLASS="quote">what is a good way to block IACV opening?</TD></TR></TABLE>
With an auto manifold you won't need to.
Also remember to get the throttle cable and bracket as well. Makes the swap a lot easier.
Old Sep 20, 2007 | 06:58 AM
JimDCXC's Avatar
Default Re: D16Y8 Intake Manifold On D16Y7 motor (ek forever guy)
what about for putting a manual manifold on an auto?
Old Sep 20, 2007 | 08:52 AM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimDCXC &raquo;</TD></TR><TR><TD CLASS="quote">what about for putting a manual manifold on an auto?</TD></TR></TABLE>
It would suck.
Old Sep 20, 2007 | 09:07 AM
Bense's Avatar
step one: cut a hole in a box
Old Sep 20, 2007 | 10:14 AM
THEDirtyDseriesWOOT's Avatar
why doesent he just get longer coolant lines and run the manual with the manual tb... im sure he got it with the y8 if it s amnaual mani.. thats what i did when i went form y7 to y8
Old Jan 3, 2008 | 06:15 AM
96hatchy's Avatar
Default Re: (THEDirtyDseriesWOOT)
damn dude i didnt think it would be this hard B/C i have a y8 manifold and i was waiting to put it on. so wut all parts do i need to put the manual y8 IM on.
and i was planning on boost so i need a solid way to block the thing u guys were talking about.
Old Jan 3, 2008 | 06:58 AM
zerovandez's Avatar
I have an automatic y8 mani if anyone is intersted. I was going to do the swap myself but got a b series instead.
Old Jan 3, 2008 | 08:08 AM
truevietluv636's Avatar
Default Re:
is it just a direct swap, would i have to change my ecu to like an ex one?
Old Jan 3, 2008 | 02:02 PM
Ek Forever y0!
Default Re: Re: (truevietluv636)
No need to change the Ecu.
Old Jan 3, 2008 | 08:05 PM
Default Re: Re: (ek forever guy)
how do i tell which manifold is from a auto d16y8? any numbers or markings? could someone send some pictures. I know someone selling one but dont know how to tell if its a y8 auto manifold.
Nov 4, 2012 07:24 PM
eddies_ls88
Dec 23, 2010 09:13 PM
GReddy_Civic
Aug 17, 2009 08:15 AM
DBOT
Sep 20, 2005 10:39 AM
sloweredcivic
Jan 17, 2004 09:27 PM
