help with my B16a2!!!
i have a b16a2 in my 2000 ek coupe... i would like to make some modifications to it such changing either the head or the block...or do you guys suggest a complete swap... im trying to keep it all motor for now..please help..need opinions...
**** poor platform for all motor. If you're on a budget you could mate your b16 head to a b20 bottom end. Get the head a port job and you'll be very satisfied.
with the b20 block do you recommend i stay with the b16a2 head or go for a gsr head.... and whats the difference between the b16 and b16a2.. horsepower? thankgs ek guy..
I would stick with the head you already have. The flow with either head is so similar stock that swapping them wouldn't make a noticeable gain.
Yes, keep the stock head, and just swap out the whole bottom end with a b20.
If you want, it would be a good idea to get some good rods/pistons for the b20 block. Some high compression pistons would make for a nice build. But you sound like you're on a budget.
A b20 bottom end can be had for ~$300-600. If you have tools it should be a straight forward swap for you.
well i am somewhat on a budget... but only for a while...i just purchased a rhd clip. i know some people think doing a conversion is pointless but i just like it.. i just want to have a ggod platform to go on and improve it little by little in the future.. im starting to be convinced the b20 bottom end is that...the Ls bottom end is the same right?
Technically it's the same block, but the bore is different. Thus giving it more displacement.
b18b
Displacement: 1834 cc
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
b20
Displacement: 1973
Compression: 8.8:1
Bore: 84 mm
Stroke: 89 mm
b18b
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
b20
Displacement: 1973
Compression: 8.8:1
Bore: 84 mm
Stroke: 89 mm
which do you recommend to be more reliable and that has the best potential? with that setup what will it times would be down the 1/4 mile... on street tires...
b18b doesn't have the issue of a weak bottom end. So if you don't have the time/money to get some stronger rods for the b20, go with the b18b. It's bulletproof.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmek »</TD></TR><TR><TD CLASS="quote">thanks for all the help.. just curious whats your setup?</TD></TR></TABLE>
Ahaha, Stock. y7 with a y8 tranny.
< College student.
No $$ for the car until my scholarship reimburses me for this semester.
I just read a lot. I've been here for 2+ years. And I'm very active.
< College student.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">b18b doesn't have the issue of a weak bottom end. So if you don't have the time/money to get some stronger rods for the b20, go with the b18b. It's bulletproof. </TD></TR></TABLE>
the rods aren't what gives out on the b20's, it's cylinder pressure
plus, i hope this guy doesn't throw a stock ls or b20 block on his b16 head and rev to 9k everyday, the stock rod bolts wont like it too much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex »</TD></TR><TR><TD CLASS="quote">the rods aren't what gives out on the b20's, it's cylinder pressure</TD></TR></TABLE>
I've heard both, but either way the bottom end IS weak.
ok now im confused...i want the block that i cant get the most power out in the long run..b20..b18b..or b18c... to have with my b16 head.... i wont be running it super hard with the block
if its your daily driver go with the gsr block b18c its way more reliable than going b20/vtec or ls/vtec...in my opinion go gsr block with new high comp pistons, valvetrain, stage 3 cams, and itb's and your set to see 9k rpms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek guey »</TD></TR><TR><TD CLASS="quote">if its your daily driver go with the gsr block b18c its way more reliable than going b20/vtec or ls/vtec...in my opinion go gsr block with new high comp pistons, valvetrain, stage 3 cams, and itb's and your set to see 9k rpms</TD></TR></TABLE>
with that set up what times would i be hitting on the 1/4 on street tires?
idk maybe low 13's, mid to high 12's not to sur it also depends on other stuff like how good the driver is and how well you kno ur car, if u hav lsd which helps, a lot of variables...but i kno 4 sur tat u'll break mid 9's on a 1/8 mi
hybrid_vtec
20
Apr 21, 2010 10:22 AM
804tuned
Engine Management and Tuning
Jul 21, 2009 12:11 PM
