HEAD GASKET QUESTION
Old Aug 21, 2007 | 06:07 PM
DSRacing's Avatar
Default HEAD GASKET QUESTION
i have a 81x89 ls/v with a gsr head milled 10-thousands and in the block 12.4:1 pistons with out vtec head, now the question, i was tryin to get a cometic gasket in a 40-thousands but could not find it but found a 52-thousands how much of a difference will it make on my set-up compression wise? the way im looking at it, it would be 52thousands gasket but since the head is milled it would be more like a 42thousands right? how much compression will i lose
Old Aug 21, 2007 | 08:32 PM
all-mtr-teg's Avatar
Default Re: HEAD GASKET QUESTION (DSRacing)
Got mines here
http://cgi.ebay.com/ebaymotors...59644
Good luck on the build
Old Aug 21, 2007 | 10:07 PM
DSRacing's Avatar
thanx but i already have that 52 on the way i should have it before friday i already found out my compression is gonna drop from 12.4:1 to 12.1:1 some im sad about it but oh well
Old Aug 22, 2007 | 04:31 AM
b20beast978's Avatar
12:1 is just about right to run with pump gas...anything higher than that is gonna need something better than 93
Old Aug 22, 2007 | 11:05 AM
DSRacing's Avatar
i didnt plan on d.d it but its ok im only gonna be on this set-up until pomona then im going bigger
jdmcivic904
Mar 2, 2011 06:35 PM
kc4door
Jan 22, 2006 05:47 PM
Kellindal
May 18, 2003 10:12 PM
mini-cRx
Feb 15, 2002 07:15 PM
