Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
NEW AFI H SERIES TURBO MANIFOLDS
Old Aug 21, 2007 | 04:23 PM
TunerHeadquarters's Avatar
Default NEW AFI H SERIES TURBO MANIFOLDS
Tuner Heaquarters is excited to announce two new AFI Honda H series turbo manifolds. The topmount is designed to fit the Prelude chassis with tubular traction bar and alternator relocation kit, and H swap set-ups utilizing Hasport mounts. Can be built with your choice of T3 or T4 flange, even allowing the fitment of such turbos as GT4094R. Bottom mount manifold does not require alternator relocation, and can only be offered with T3/T4 turbo options. Manifolds comes standard with a 44mm wastegate flange. Constructed from WELD ELL 8 gauge 304L stainless steel, each manifold is hand tig welded while using back purge technique. All flanges are ½ inch thick and CNC machined. All manifolds carry a limited lifetime warranty.
H Series Top Mount
Retail price $1050.00
Introductory Price $899.00
H Series Bottom Mount
Retail Price $899.00
Introductory Price $ 749.00
Modified by TunerHeadquarters at 3:07 PM 8/22/2007
Old Aug 22, 2007 | 11:29 AM
Default Re: NEW AFI H SERIES TURBO MANIFOLDS (TunerHeadquarters)
PM's- Thanks
Old Aug 23, 2007 | 07:55 PM
PM'd....I have two top, and two bottom in stock.
Old Aug 25, 2007 | 11:21 AM
BUMP
Old Aug 26, 2007 | 08:38 PM
PM's replied.....Thank You
Old Aug 28, 2007 | 05:58 AM
-Bionic-'s Avatar
Former Sponsor
a/c and p/s compatible?
Thanks, looks great.
Old Sep 1, 2007 | 11:33 AM
PM'd- thanks
Old Sep 3, 2007 | 01:55 PM
Thanks..orders shipped.
Old Sep 3, 2007 | 07:12 PM
highschooler's Avatar
can you get an a/c compatible manifold, either top mount or bottom mount for h22 in civic with hasport mounts?
Old Sep 4, 2007 | 03:29 AM
1epmugenlude's Avatar
great to see some new manifolds for the h22. will these work in 4th and 5th generation preludes? Also I wanted to know if the bottom mount will allow you to use a/c as well. I will not have to relocate the p/s either? thats grrrrrreat....
Old Sep 4, 2007 | 07:24 PM
And a downpipe/dumptube package?
Old Sep 7, 2007 | 10:30 AM
Old Sep 9, 2007 | 11:09 PM
Ransom's Avatar
Would like to know if both the manifolds can be made ac/ps compatible in the 4th gen chassis.
It would probably be a good idea to respond to the questions in the thread instead of through pm so you dont recieve the same questions over and over.
Old Sep 10, 2007 | 05:11 PM
boostedlude01's Avatar
Will these work in a 5th gen prelude? Any mods required?
Old Sep 12, 2007 | 03:34 PM
Both top and bottom will fit 5th gen Prelude, and both are non ac compatible. Top mount you must relocate the alt. Thanks- Brent
Old Sep 14, 2007 | 12:03 PM
Thanks..
Old Sep 24, 2007 | 12:42 PM
PM'd- Parts shipped Thanks
Old Oct 10, 2007 | 12:44 PM
Shipped- Thanks....
Old Oct 10, 2007 | 01:03 PM
streetracer6rpt's Avatar
looks great
Old Oct 18, 2007 | 06:27 PM
Thanks...
Old Oct 20, 2007 | 01:04 PM
boots89's Avatar
I have the top-mount manifold and it is awsome. Jeese did a great job
Old Oct 23, 2007 | 10:29 AM
Thanks...
Old Oct 26, 2007 | 10:49 AM
Parts shipped..
Old Oct 26, 2007 | 01:15 PM
boots89's Avatar
PM sent!!!
Old Oct 27, 2007 | 09:45 AM
Answered-Thanks
