Steering wheel Removal?
Old Aug 21, 2007 | 03:43 PM
js2k01's Avatar
Default Steering wheel Removal?
does anyone know where i can find a PDF file on to replace a 94 honda accord steering wheel. Thanx.
Old Aug 21, 2007 | 09:10 PM
caliskier's Avatar
Default Re: Steering wheel Removal? (js2k01)
Don't have a pdf, sorry. If it has an air bag it probably is a pain, but the 91 model and the gen before that should have 4 screws on the back side. You will need a short phillips head. You remove those, pull the cover off, and be sure to disconnect the horn wire. Next I think is a 17mm nut that holds the steering wheel on. Unscrew that and pull the wheel off. You might want to mark it first before pulling it off if you can that way you can be sure the wheel will be in the correct positon when you drive straight down the road. You should not need a puller to remove it.
Old Aug 22, 2007 | 12:31 AM
Honda_Accord's Avatar
Default Re: Steering wheel Removal? (caliskier)
Ya its a little bit of a paint with an air bag, you should see two like pockets that are covered by plastic on either side of the steering wheel u pop those off and u should see two golden big screws you gotta unscrew those.. now i will tell you that on mine, those suckers where in there so tight that i actually had to drill them out, after that then airbag will pop out and u just start disconnecting.. I didnt need a puller, i just tugged and shook the hell out of mine and it came off, but some people said they needed one .
and like caliskier said, please mark where ur stuff is at, i didnt and it was a pain in the *** to get my new steering wheel to steer the car straight lol.
ps i do have the pdf for this, but we are not allowed to post helms manuals. If you absolutely need it, tell me.
DC5mike
Jan 12, 2008 08:15 PM
hanskies
May 24, 2006 03:34 PM
sushib01
Aug 22, 2004 10:26 PM
b16acrxer
10
Dec 2, 2003 06:28 PM
kikkoboyie
Sep 15, 2002 02:55 AM
