gauge cluster question
ok i have an 89 crx si, my cluster burnt so i have a cluster out of an 89 hatch, the speedo and turn signal indicators work but nothing else. does it have to be out of a crx? i am lost and really need to get the cluster working so i can drive the car, i really dont want to have to add extra gauges can anyone help?
[Quote]
There are some inaccuracies with the 88-89 pins outs, the 2 CRX clusters I had from the 88-89 vintage were nothing like the poster information, so I had to tract down/test the proper wiring. I think B18c5CRX was using 88-89 hatchback harnesses, which may have been different altogether than the 88-89 CRX pins outs. Here are my findings based off what I had to test and figure out. For the most part the wire colors in the CRX match up with the 90-91 format. Aside from the illumiation, which to the best of my knowledge, the red and red/black wires need to be swapped when converting to anything newer….it has something to do with the way the 88-89 dimmer circuit works.
· A1 Left Signal B1 Gnd.
· A2 IGN 12V (+)(Yel) B2 VSS
· A3 Fuel Gauge B3 Empty
· A4 Oil Press B4 E-brake
· A5 CEL B5 Diver Seat Belt
· A6 Illumination(red) B6 High Beams
· A7 Illumination(red/blk) B7 Trunk/Hatch
· A8 Empty B8 Right Turn Signal
· A9 IGN 12v (Blk/Yel)
· A10 Battery (Blu/Wht)
· A11 Tach Signal
· A12 Temp Gauge
[\quote]
http://www.geocities.com/speed...r.htm
Might want to double check your wiring.
· A11 Tach Signal
· A12 Temp Gauge
[\quote]
crex23
May 17, 2009 04:06 PM
