How to fix a seized front license plate bolt on front bumper for 95 hatch--with pics--
Ok so I just finally got my plate for my hatch
but one of the license bolts is stuck
and the previous owner tried to remove it and scratched up the front bumpter
So, I decided to fix it the right way, it was very easy. If you like to work on your car, can remove the 7 bolt to take off you front bumper cover you're almost done
Here is how to
This is problem with the f***ed up paint
take off your bumper
You will need one of these for each side you a seized bumper, I ordered 2 but i only needed one. I'd rather replace them in a pair since its cheap.
To remove the bolt, take a pair of pliers to grab the bolt. Then take a hacksaw and cut the bolt. Take care not to damage your bumper, if you have a very nice bumper I would put blue painters tape around the area to make sure you don't damage it.
This is what the everything looks like removed from the bumper
There are 2 tabs that it in place...make sure you install the piece right, if you not sure take a look at the one that you have not removed yet.
To install, you will need to thread in 2 bolts. Alternate the screws when you are tightening so that its even
This takes 10-15 minutes max as long as you familiar with how to remove the bumper and have the proper tools. As I continue to work on the hatch I will post how-tos up. Later
Here is how toThis is problem with the f***ed up paint
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulletspastsunset »</TD></TR><TR><TD CLASS="quote">i would have just cut it out, and fill those holes with the oem plugs
but when you live in NJ, you need a front licence plate.
</TD></TR></TABLE>but when you live in NJ, you need a front licence plate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">
but when you live in NJ, you need a front licence plate.</TD></TR></TABLE>
exactly..they pull over hondas for any reason, this is a way to give them one less reason to do so..here is the final pic
My fronts have OEM plugs (dealership actually installed them when I brought it for my dealer-accessory install w/ the front plate hardware removed), but when the state decided to change it's plate design I discovered one of my rear bolts had seized. After soaking it in penetrant I twisted the head right off the bolt. Drilled it out and used a coarse-tooth stainless steel screw in it's place. Which is probably just as corroded & seized now. The less bolts you have to worry about the better, at least in my book.
Good writeup though.
My state (Illinois) requires front plates by law. I've had no IL front plate installed for over 15 years now, and have only gotten a ticket 4 times for it. Moved here from Michigan around that time, MI only requires the rear, and I never heard a convincing argument for requiring a front plate.
I'd say at least 1 in 4 cars I see with IL plates don't have the fronts installed, so it's not as though I stand out like a sore thumb.
Frase_civic
Jan 24, 2014 02:30 PM
