instructions of how to replace the dizzy rotor?
Old Aug 21, 2007 | 12:17 PM
crazyguy's Avatar
Default instructions of how to replace the dizzy rotor?
i cant find retaining screw of the rotor and was told need to turn the car over and i will be able to see that screw...what exacly i need to do to tur nthe car over? like disconnec the battery terminal or unplug the spark plug wires or ?
thanks
Old Aug 21, 2007 | 12:19 PM
vlc92189's Avatar
Default Re: instructions of how to replace the dizzy rotor? (crazyguy)
all you do is.. take off the 4 bolts holding the distributor cap ( the black thing) then theres your rotor, its one bolt holding the rotor on, just unscrew the screw and replace, thats it.
Old Aug 21, 2007 | 12:32 PM
crazyguy's Avatar
Default Re: instructions of how to replace the dizzy rotor? (vlc92189)
the problem is i can not find the bolt.it was not turn to the open end for me to unscrew it
Old Aug 21, 2007 | 12:34 PM
EL Vap133's Avatar
Crank it real quick, works for me.
Old Aug 21, 2007 | 12:36 PM
24TEN's Avatar
PHANTOM MENACE
You can put your car in neutral and using the correct size socket, you can spin the motor at the crank pulley until you see it. The easiest way is to put the car in neutral and have someone turn the key real quick, just enough to spin the motor without it firing up. Do that enough times and eventually you'll get the rotor turned over to the side with the screw. Hope that helps
Old Aug 21, 2007 | 12:37 PM
crazyguy's Avatar
Default Re: instructions of how to replace the dizzy rotor? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Crank it real quick, works for me. </TD></TR></TABLE>
crank it when all the spark plugs unplug or ?
burnitdown's Avatar
either turn the key real quick and look to see if it's on top, it may take a few tries. or turn the crank with a 17mm (i think) socket
Old Aug 21, 2007 | 01:08 PM
pimpinblackcivic's Avatar
the cap will be off so dont worry about it firing, just turn it on and off until you see the screw this uses the starter motor to turn over the engine
slateEKsi
Mar 13, 2011 05:50 PM
ShinotakuX
Feb 22, 2008 10:05 AM
Jameson
Feb 15, 2008 10:59 AM
93SSPHatch
May 30, 2002 02:55 PM
gsr squirrel
Apr 25, 2002 07:08 PM
