Pass Axle won't go in (searched)
Old Aug 21, 2007 | 10:39 AM
staticCRX's Avatar
Default Pass Axle won't go in (searched)
'91 CRX Si with stock D16A6
I just replaced the clutch in my car and now I'm trying to put the passenger side axle in. It'll go in far enough for the threads to catch and spin but it won't go in that extra inch. I've used as much force as I can (ended up replacing the axle because I busted the boot hitting it) and the thing won't budge past the threads. I've tried pulling it completely out and rotating it but it still won't work. I searched but found mostly removals and compatible questions.
Help? THis is all I need to get done before I can start the thing after 9 months.
Old Aug 21, 2007 | 10:52 AM
90_Si's Avatar
Default Re: Pass Axle won't go in (staticCRX)
Mine were also hard to get in. I just screwed with it untill it finally went in. I put something on the edge of axle where it goes in and hit that with a hammer. Just do it in such a way that you arent damaging or cutting the boot, it is possible if you are careful about it.
Old Aug 21, 2007 | 11:06 AM
alscrx's Avatar
Ok, first off, When u slide the axle into the tranny does it fully go in???
If not you should not be putting the other end into the spindle yet and trying to force it in my tightening that 32mm axle nut!!!!!!!!!!
The axle c clip must be sitting flush and you should be greasing the splines and c clip on the axles. Next, its all about the angle in which you hold the axle. I found that out when i installed my crx b16 axles. I held it down too much and it would not slide all the way in and lock in. When i held itmore up towards the hood it slid right in and i heard the click. Then i doubled checked by pulling on the solid part near the tranny. Not on the axle shaft cause you will riun the Joints!
Hope this helps..
Old Aug 21, 2007 | 11:42 AM
staticCRX's Avatar
"greasing the splines and c clip"
good call. Thanks for the info guys. I'll go screw with it some more. I knew not to tighten the 32mm.
Old Aug 21, 2007 | 01:36 PM
alscrx's Avatar
Default Re: (staticCRX)
Yeah remeber try pushing in while moving the axle shaft up...Assuming your laying on the ground like me,lol. Should slip right in!
Good luck-
PhantomPharter
25
May 4, 2012 01:04 PM
aziaticvang
Dec 27, 2007 05:22 PM
See Are X
Apr 28, 2006 07:42 PM
SkyLinER
Jul 6, 2004 07:04 AM
