how to purchase a used motor and transmission
Old Aug 21, 2007 | 10:39 AM
cone junkie's Avatar
Default how to purchase a used motor and transmission
i am planning on purchasing a used motor/trans to build it for autocross competition (SCCA, EP). unfortunately i dont know a thing about purchasing a motor let a lone building one(but i'll tackle one issue at a time).
i plan on building/rebuilding the entire block and head.
i currently have a D15B1 motor, i will be looking for is a D16A6 and a trans to match it.
so my question is what things/signs should i be looking for/looking out for when purchasing a used motor/trans?
thanks.
Old Aug 21, 2007 | 12:18 PM
donnie_437's Avatar
Default Re: how to purchase a used motor and transmission (cone junkie)
everyone takes risk when purchasing a used motor just because naturally...its a USED motor. you dont know what kind of abuse the motor had in the past. best thing to do is look around for a reputable engine/trans importer. make sure they have a warranty(usually 30day start up) and do a compression leak down test.
Old Aug 21, 2007 | 07:30 PM
Default Re: how to purchase a used motor and transmission (donnie_437)
would the risk you mentioned above also apply to a motor if i plan on rebuilding it?
Old Aug 22, 2007 | 11:14 AM
bump
Old Aug 22, 2007 | 12:11 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cone junkie &raquo;</TD></TR><TR><TD CLASS="quote">i am planning on purchasing a used motor/trans to build it for autocross competition (SCCA, EP). unfortunately i dont know a thing about purchasing a motor let a lone building one(but i'll tackle one issue at a time).
thanks.</TD></TR></TABLE>
why bother swapping to a d16? its virtually the same thing as your d15 honestly i ran both and they pretty much were identical in power.... especially if you plan on rebuilding the engine. ... for that amount of money you can go with a b16 at least.. or even b20 swap..
Old Aug 22, 2007 | 12:24 PM
Default Re: how to purchase a used motor and transmission (h22crxpwr)
i was thinking of swapping b/c i thought a d16 would have a larger parts selection than my d15.
i am planning on staying in class for autocross. a b16 or b20 would bump me out of class to DM and would also add ~+75lbs to the front. and from what i have been reading i would have a better chance of staying in powerband with a d16 vs a b16 esp. on an autocross course.
Old Aug 22, 2007 | 01:54 PM
DonF's Avatar
You need to ask this in the autocross/road racing section if you want a good answer.
Old Aug 23, 2007 | 10:31 PM
Stein's Avatar
Default Re: how to purchase a used motor and transmission (DonF)
compression/leakdown.
make sure it has a startup warranty
turboteg90
Sep 4, 2008 03:09 PM
