Engine idel up and down. IVAC issue ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb18Tkid »</TD></TR><TR><TD CLASS="quote">thats what i ment lol had a brain fart. this is the same prob my bud had. do the tps sensor</TD></TR></TABLE>
As in, the TPS sensor was bad altogether? Or just misadjusted?
Yeah, my B16A2 also idles weird. Sometimes at a light i turn on the AC just to up the rpms. I just replaced the tps by means of swapping the entire throttle body. whats the best way of tracking down the vacuum leak?
How mine idles is... 400-600rpm dip down bounce when the extra gas is given back up to 800 then to 600 dip repeat.
how does one clean the IVAC?
try cleaning its surface and sensor and if all else fails replace it.
ive got a weird idle too..... but its the crower stgII cams
im currently having same problem with my 00 civic si its got a greddy turbo kit running 7psi but the check engine light came on did a scan came up code 13 which is atomospheric pressure sensor. i was told it was the map sensor. but it also idles at like 400 to 1200 rpms
Holy crap me too and ive checked the CEL and i get the MAP censor And IACV and i haven't cleaned that but ima try tomorrow!
I also have a lil pipe coming out of the Fuel Filter and i dont know what i connects too
ohh i have a d15b Vtec
I have cleaned mine and have no more problem.
One thing I notice is I have to make sure all the parts seal good before putting in back. I put silicon to seal the parts is because the rubber that does the sealing get too old and broke.
so to clean it you just take off the entire throttle body and clean everything with throttle body cleaner or brake cleaner. i will try this tomorrow and see what happens. i really dont want to buy another part if i dont have to.
if you clean it with carb clean or brake clean, you need to spray some lube in afterwards because the cleaner will dry up the rubber piece inside
Erratic idle can also be caused by air trapped in the cooling system. So, in some cases, properly bleeding the cooling system can solve this type of idle problem.
