ITR Running Rich HELP! No Codes, Oxygen Sensor? Analize Emmision Test Results.
Old Aug 21, 2007 | 08:25 AM
Freeltec's Avatar
Default ITR Running Rich HELP! No Codes, Oxygen Sensor? Analize Emmision Test Results.
Hey Guys,
Im just about to go on a road trip out to BC, and My 100% stock ITR is running rich. I took it to get Emission Tested and here are the Results:
40km test:
HC ppm- limit=68
Reading=316
FAIL
CO% Limit= 0.38
Reading=6.32
FAIL
NO ppm- limit =0526
Reading= 91
PASS
Curb Idle Test:
HC ppm- limit=150
Reading=159
FAIL
CO% Limit= 0.7
Reading=0.11
PASS
NO ppm = NA
Im wondering if I need to replace my 02 sensors. They have both been in there since i bought the car. (60,000km+). Do I need to replace both sensors?
I replaced the cat last year, the car has fresh oil, plugs and cap and rotor. The air intake is stock and the filter is clean.
I Think its the oxygen sensor but the car has no codes. Please let me know what you guys think and if i need to replace both sensors or just 1.
Old Aug 24, 2007 | 10:40 AM
Freeltec's Avatar
the car passed with flying colours after i changed the o2 sensor. Thanks for all the help ITR douchebags!
Old Aug 27, 2007 | 08:06 PM
Slimmonkey559's Avatar
Default Re: (Freeltec)
Which sensor did you replace? Front, Rear, or both? I only ask because I am experiencing similar issues.
Old Aug 27, 2007 | 10:21 PM
Soichiro's way@MF's Avatar
Default Re: (Slimmonkey559)
should have been the primary because the secondary only reports what the catalyst is doing. The primary O2 is responsible for gauging the fueling augmentation needed.
zerovandez
Feb 2, 2013 07:28 PM
border919
Dec 6, 2010 04:21 AM
hybrid90
May 12, 2010 05:05 PM
loup05
Aug 11, 2005 08:06 AM
