Starter Welder? Y/N
Old Aug 21, 2007 | 08:02 AM
91ed9's Avatar
Default Starter Welder? Y/N
What do you guys think of this welder as a nice starter its flux core and also a gas Mig welder (which i would be useing mainly )
http://www.harborfreight.com/c...94164
or
help woul be appriciated greatly im kinda new to the welding thing but ive used an arc welder for years with some old *** machines my dad has :-p
i should be buying this welder within the week so i would like to hear some of your "expertice" opinions
thanks
-John
Old Aug 21, 2007 | 08:06 AM
91ed9's Avatar
Default Re: Starter Welder? Y/N (91ed9)
or this one
http://www.harborfreight.com/c...93793
Old Aug 21, 2007 | 11:19 AM
nonsense's Avatar
Looking at the first ones duty cycle would make me avoid it.
Welding current range: 58 to 110 amps
Duty cycle: 60% @ 55 amps, 28% @ 80 amps, 15% @ 110 amps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Duty cycle is a welding equipment specification which defines the number of minutes, within a 10 minute period, during which a given welder can safely produce a particular welding current.</TD></TR></TABLE>
At 55 amps (how can you run it that low if the lowest is 58??? anyway) it has a duty cycle of 60%. So you can weld 6 of the 10 minutes at the lowest setting. If you're just tacking a few things together this might be ok.
At full power (110 amps) you can only weld for 1.5 minutes then let the machine sit for 8.5 minutes. Doesn't seem like usable range.
Personally, I'd look online for a good, used welder before spending the money on a cheap new one.
Old Aug 21, 2007 | 02:09 PM
91ed9's Avatar
Default Re: Starter Welder? Y/N (nonsense)
what would you recommend a good welder thats low priced very short on budget and im not looking for somethign that could handle welding everyday all day i just need it to fab up things like exhausts, manifolds support braces stuff like that covering holes in body
you know what i mena
Old Aug 21, 2007 | 02:28 PM
DESTROYER's Avatar
just get a home depot welder. we still use it in the shop for doing small scale stuff, even welding in the base plates for roll cages.
Old Aug 22, 2007 | 07:14 AM
nonsense's Avatar
I'd look for a used Lincoln, Miller, or Hobart welder. Supposedly the welders sold at HD and Lowes are not as good as the same models sold elsewhere (i.e. HD sells a Lincoln, but it uses cheaper parts to keep costs down). I've not seen hard evidence of this and for occasional use it will probably be fine.
splinters8181
Honda CR-V & Element
Sep 1, 2011 10:53 AM
CeoStatus0
Sep 17, 2007 08:45 AM
Sukebei Oni
Mar 16, 2003 01:21 AM
