which cams suit me the best?
i've been looking a lot at the m24x's, the skunk2 3's as well as the pro2's, and possibly if i can swing it, some jun3's. the setup is as follows:
gsr block
P30's (+.25mm)
springs/retainers (depends on which i go with)
flat faced valves
hytech or sms header
skunk2 pro IM w/hondata gasket
possibly if money goes well some headwork
2.5" exhaust
64mm TB
IM could possibly change..... lookin for 215+whp
Modified by EGunit at 11:22 AM 8/21/2007
gsr block
P30's (+.25mm)
flat faced valves
2.5" exhaust
64mm TB
with the p30's and flat faced valves your CR should be bumped to around 11:5- 11:7 assuming you run a oem 3 layer headgasket and no milling was done to the head so some stage 2 cams or rocket m22's should be ok
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu »</TD></TR><TR><TD CLASS="quote">Pro 3</TD></TR></TABLE>
nice try, im not stupid.
i was looking at the m22's as well, they def look like they make solid power. i was also thinkin about using a two layer head gasket....but im still undecided on that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gong Show »</TD></TR><TR><TD CLASS="quote">blox or buddy clubs would be my choice. </TD></TR></TABLE> When you tested those against the ones he mentioned, what were the results?
If you got GSR head with VJ from RLZ/Rocket/DFE, do Performer X IM match ported, good stage 2 style cam, Hondata S100/S200 (crome if on budget) and you will be
205whp if you get lucky. 215whp are pro builder numbers for true 11CR 1.8L motors.
Scientific testing performed as follows in some suburban tract:
Toss "fair" coin.
If heads --> Blox wins, hands down.
If tails --> BC wins, hands down.
If coin stands on edge --> Rocket wins and we "party like it's 1999" because "they might be giants" just say "goo goo gjoo, I am the walrus" and "just let it be" "strawberry fields forever" "say bye bye Ms. American, pie. I drove the chebby to the lesbi but the lesbi was dry."
Toss "fair" coin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote"> When you tested those against the ones he mentioned, what were the results?</TD></TR></TABLE>
I'm just giving my opinion from the researc I've be reading. Blox C's or BC4's would probably get him close to the results he's looking for.
If I'm not allowed to state my opinion, please let me know and I'll never post in this forum again. Please let me know all mighty all motor gawd...
pfffft
pfffft
as far as headwork goes im looking for at least a mild p&p if not a lil more. im not opposed to deviating from the cams i listed but as far as blox goes, i've seen some decent results but theres something that just keeps me away from them. no experience/reason just a gut feeling. if i get more than a valve job, will any of the ones i listed come into play? assuming of course i use the thinner head gasket....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe »</TD></TR><TR><TD CLASS="quote">Most cams will work fine. Your choice will be based on if you want to pay extra for that extra power etc.</TD></TR></TABLE>
im almost certain ill be gettin the head ported. i just wanna make sure if i cough up a lil extra money on more cam that it'll be worth it and actually make the power that it should. i.e. do it "right" the first time
on the subject of the RM stuff.....how much difference is there between the m22x and the m22xx? same question with the 24x/xx. i find some advertised numbers and some with the @.050" numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">x means 1 large and 1 small primary like stock cams, or the old Skunk cams, copy cams. xx means both primarys are larger, like the PRO's or Toda. </TD></TR></TABLE>
ok then....guess that explains why they listed the primary specs too on the xx's. so the m22's are comparable to pro1's and the 24's somewhat correspond to pro2's or not?
22's and Pro1's are comparable, the 22's typically carry power a bit higher, and the Pro1's having a bit of a stronger midrange. The 24's are smaller than the Pro2's, but I would like to see them against eachother in a healthy 2 liter
What is this motor going to be used for?
https://honda-tech.com/zerothread/2012979
this car see's(or use to see)both street/strip/road course.
