My Antilag on crome vid
Old Aug 21, 2007 | 12:26 AM
a1320honda's Avatar
Default My Antilag on crome vid
There was a big discussion of getting antilag to work on crome. this is how my car was doing with it. I was leaving on 8-9psi. you can kinda see it shooting flames out of the downpipe underneath the car.
And ignore the smoke, the week prior i had killed a ringland on one of the pistons so i figured this was a good time to try to get the antilag bugs worked out. And since i was building way more boost on the line and leaving on very sticky tires, the clutch decided to blow up, so i had just enough clutch that i had to let it rev down to shift.
Just thought id share.
http://www.youtube.com/watch?v=uIhzZYOeCWM
Old Aug 21, 2007 | 03:57 AM
2point2's Avatar
Default Re: My Antilag on crome vid (a1320honda)
nice.
Old Aug 21, 2007 | 05:10 AM
fast2camciv's Avatar
so are you still running the 10psi in your sig? so your pretty much making full boost off the line then huh?
and what where your final settings?
Old Aug 21, 2007 | 08:32 AM
a1320honda's Avatar
Default Re: (fast2camciv)
Ya im still only at 10psi. i dont have the antilag setup on it now cause its got the B20 in it. And you need to have a vtec setup in cause all the adjustments have to be done on the low cam. Settings are -2* of timing from 5k-6krpm, and +20% fuel in the same region, and the FTL set at 5800.
Old Aug 21, 2007 | 08:39 AM
TunerShark's Avatar
Default Re: (a1320honda)
interesting, what kind of manifold & turbo do you have? and how do they hold up with the raw fuel being dumped and combusted in the manifold?
and how hard is it to tune an anti lag system on crome? id like to try it, but i dont want all my parts to go to ****.
Old Aug 21, 2007 | 08:47 AM
simply's Avatar
Default Re: (TunerShark)
that sounds like a lil baby anit lag. Does crome have a "real" anti lag system?
http://www.youtube.com/watch?v=DErQyuzd6KY
Old Aug 21, 2007 | 09:23 AM
a1320honda's Avatar
Default Re: (simply)
Im using cheap ebay manifold and t3/t4 57trim turbo. im sure there are some lasting effects of the setup, but really inside the car it doesnt seem too drastic. As for Crome having a real antilag setup....I think theres supposed to one on CromePro, but i dont know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simply &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.youtube.com/watch?v=DErQyuzd6KY</TD></TR></TABLE>
Thats what i want mine to do LMAO!
Old Aug 21, 2007 | 09:47 AM
adseguy's Avatar
Crome does not have anti-lag yet.
I've done real anti-lag with a bunch of others using Crome, but it doesn't render the car too drivable as their are bugs with the ign. cut script. It did build 15psi of boost off the line at 5400rpm on a 57trim, but like I said this was unsafe to drive on.
Real anti-lag needs a lot of ignition retard (in the negatives) and lots of fuel being dumped along with an ignition cut instead of fuel being cut at the desired RPM.
Old Aug 21, 2007 | 09:55 AM
a1320honda's Avatar
Default Re: (adseguy)
Ya the driveability wasnt the greatest. But i figure if i can get it dialed in for track use, ill just burn 2 chips, one with the antilag, and one without, and just run the race setup at the track.
Old Aug 21, 2007 | 10:33 AM
quicksilver1689's Avatar
i ♥ snails
i think you got beat
http://youtube.com/watch?v=puG...earch=
Old Aug 21, 2007 | 10:49 AM
90dxhmt's Avatar
Default Re: (quicksilver1689)
Im running a LS and Crome I went into the columm right where i launch at 7000-7200 and pulled all the timing out between 3" vacum to 8psi and dumped a bunch of fuel in and it builds 9psi for me.Im never at the high of rpm and that low of boost driving so its fine as im running 15psi.It is enough to be able to launch decent all though i could use a little more.
Old Aug 21, 2007 | 11:02 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">i think you got beat
http://youtube.com/watch?v=puG...earch=</TD></TR></TABLE>
BAHAHAHAHAAHAHA
Old Aug 21, 2007 | 11:24 AM
A.E Motoring's Avatar
Default Re: (mtber)
LMFAO WTF, a battle
http://youtube.com/watch?v=Zdu...earch=
Old Aug 21, 2007 | 12:08 PM
PURO~SURCAL's Avatar
Default Re: (Dual Cam Racing)
boOBARUS ARE ANNOYING AS FAWK.. ....
Old Aug 21, 2007 | 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Crome does not have anti-lag yet.
Real anti-lag needs a lot of ignition retard (in the negatives) and lots of fuel being dumped along with an ignition cut instead of fuel being cut at the desired RPM.</TD></TR></TABLE>
what do you mean it was unsafe to drive on? if you set vtec low enough so that you dont dip into low cam on a lazy shift, you should never be in the anti lag reigon right? wich ign. cut script were you using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simply &raquo;</TD></TR><TR><TD CLASS="quote">that sounds like a lil baby anit lag. Does crome have a "real" anti lag system?
thats not anti-lag..thats a gang war in the stands lol
Old Aug 21, 2007 | 12:59 PM
teddy_dc2's Avatar
nice, love the vids.
Old Aug 21, 2007 | 01:46 PM
alpha's Avatar
Car I tuned a while back. About 18lbs - 20lbs on pump gas. The race gas was alot more fun If I remember correctly it was running a GT35RLS
2-Step
Old Aug 21, 2007 | 05:45 PM
triple_s1x's Avatar
Default Re: (fcukJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcukJDM &raquo;</TD></TR><TR><TD CLASS="quote">boOBARUS ARE ANNOYING AS FAWK.. ....</TD></TR></TABLE>
LOL, and ummm yea the honda on the 2step must be like sex to yours ears.
Old Aug 22, 2007 | 06:05 PM
RIP V8s's Avatar
Default Re: (triple_s1x)
sorry for being a retard but can someone explaine the anti lag to me and how it works.
Old Aug 22, 2007 | 07:21 PM
teddy_dc2's Avatar
correct me if i'm wrong but the 2 step rev limiter lets you rev to a certain rpm and boost, it's to get the car into boost right at launch to avoid boost lag. something i need in my car...
Old Aug 22, 2007 | 08:07 PM
adseguy's Avatar
Default Re: (RIP V8s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP V8s &raquo;</TD></TR><TR><TD CLASS="quote">sorry for being a retard but can someone explaine the anti lag to me and how it works.</TD></TR></TABLE>
By retarding the ignition so late that the still hot flame front travels out of the exhaust valve to the turbo. Dump extra fuel in and you get more explosion. This spools the turbo up when you technically have no load on the car. Nice benefit, but it hurts the exhaust valves and turbo by banging them with explosions and excess heat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong but the 2 step rev limiter lets you rev to a certain rpm and boost, it's to get the car into boost right at launch to avoid boost lag.</TD></TR></TABLE>
No a 2-step rev limiter is exactly that......a 2nd rev limiter. All this does is either cut fuel (what most modded Honda ECU's do) or cut ignition. Either way it doesn't describe what I explained above.....that is anti-lag
JJsMotorsports
May 23, 2011 04:15 PM
blackeg
Oct 16, 2006 06:09 PM
Si_Element
Aug 18, 2006 12:22 PM
RuthlessEF-9
Dec 3, 2002 08:51 PM
BLKCRX
Apr 28, 2002 09:40 AM
