shift lock solenoid and transmition
Old Aug 20, 2007 | 08:56 PM
dailyekhatch's Avatar
Default shift lock solenoid and transmition
is it rare for a shift lock solenoid to go out? my car will not go into gear and its stuck in park. i have to put it in neutral then i can drive it. i took the entire center console out and check to make sure that there wasnt any junk in there. i did how ever find one wire that was spliced and reatached. i just put some electrical tape on it and made sure it wasnt loose, and all the other wires were ok. then my car shifted perfect for about 10mins from park to drive. then it went back to the way it was. now when i turn it on it will light up the parking light and the d4 light will come on for about 5 seconds then turn off. i also heard that theres a sensor were the brake is for the shift lock, is this true? also i'm having problems with my tranny it will only shift in high gears. the auto 1st gear will change at around 25mph and 2nd gear will change around 55-60mph.
Old Aug 20, 2007 | 09:26 PM
Default Re: shift lock solenoid and transmition (dailyekhatch)
Old Aug 21, 2007 | 06:10 AM
anyone???
Old Aug 21, 2007 | 06:19 AM
ifIexplode's Avatar
Your D4 light will blink like a check engine light when you Jump the ECU. I havent been able to find online anywhere the Codes for Honda auto transmissions. Do you have any check engine lights?
Old Aug 21, 2007 | 06:23 AM
Default Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">Your D4 light will blink like a check engine light when you Jump the ECU. I havent been able to find online anywhere the Codes for Honda auto transmissions. Do you have any check engine lights? </TD></TR></TABLE>
nope no cel's, thanks for replying
Old Aug 21, 2007 | 08:54 AM
Default Re: (dailyekhatch)
i just changed the shift lock solenoid and its still doing the same thing any suggestions???????
Old Aug 22, 2007 | 07:43 AM
i also changed out the brake light sensor for the pedals. and the blue relay box next to the center consol and still nothing.
??????????anyone???????????
Old Aug 22, 2007 | 07:55 AM
91hybridDX's Avatar
did you check to see if there are any fuses and or relays related to the solenoid?
ektuner39's Avatar
From: no shes not Christina Aguilera, Hustle Hard or Go HOME
have you tested the wire input / output from that relay box you switched out over to the solenoid? test to see if your getting any power/ground when you press the brake pedal down over to the solenoid wire under the center console. your going to need a DMM to test the polarity on the wire.
Old Aug 22, 2007 | 08:17 AM
Default Re: (ektuner39)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hybridDX &raquo;</TD></TR><TR><TD CLASS="quote">did you check to see if there are any fuses and or relays related to the solenoid?</TD></TR></TABLE>
i'm going to check that out today. by any chance would you or anyone know where the fuse's are located for the shift lock solenoid??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ektuner39 &raquo;</TD></TR><TR><TD CLASS="quote">have you tested the wire input / output from that relay box you switched out over to the solenoid? test to see if your getting any power/ground when you press the brake pedal down over to the solenoid wire under the center console. your going to need a DMM to test the polarity on the wire. </TD></TR></TABLE>
i'm going to do that today i know that the solenoid is working cause i put a 12v current staight to it and it poped like a vtec solenoid.
Old Oct 11, 2007 | 06:06 PM
teamsol's Avatar
going through a similar problem...did you fix it?
Old Feb 25, 2010 | 04:08 AM
REAPER101's Avatar
bump
Old Aug 30, 2012 | 03:05 PM
ceciliajohnson's Avatar
I have an awkwardly similar issue with my 97 Honda accord auto, i never experienced any transmission slippage. One night driving in D4 randomly i felt like it slipped into neutral. I turned the car off and started it 3 to 5 mins later it would engage in any gear and responds accordingly for 30 sec to a min then feels like neutral this is with the shiftier into that corresponding selected gear. the first thing i checked was gear oil it was good. checked fuses. had a good friend check the axles he said it seems intact. assumptions from an experienced mech is its doing something called "neutralling up". diagnosis are not done cause they checking the codes, engine light is on and they gonna check the solenoid as well. unless any one has some good 2 cents.
Old Aug 30, 2012 | 06:39 PM
jbpnoman's Avatar
Try posting in the Accord section, this is the EJ section. Also, try not bumping a 5 year old dead thread. Thanks.
Old Sep 3, 2012 | 10:28 PM
Thanks for being so helpful!!! {sarcasm}
Old Sep 3, 2012 | 10:45 PM
jbpnoman's Avatar
Anytime! Thanks for being such a useful forum member, searching, and reading thoroughly before posting!
Yovngroyal
Jun 27, 2019 07:32 PM
Wrork
Jan 2, 2019 07:53 PM
Kalvee1
Honda Civic (2006 - 2015)
Mar 26, 2016 09:55 AM
ratprod
Oct 5, 2014 04:32 AM
