? - k20 crx - ?
Old Aug 20, 2007 | 06:31 PM
iheartmyh0nda's Avatar
Default ? - k20 crx - ?
are there mounts and everything necessary to do a k20 swap in a crx? is everything made needed for it to run right?
Old Aug 20, 2007 | 06:33 PM
Mr. Giggles's Avatar
Default Re: ? - k20 crx - ? (iheartmyh0nda)
You can get a mounts from hasport, but you need to have the passenger mount welded..
k20a.org
Old Aug 20, 2007 | 06:34 PM
EFinawesomeman's Avatar
Hasport makes just about everything you absolutely need for the swap, its expensive but they have it, and i'm pretty sure they also the things you nee dto relocate the alternator
Old Aug 20, 2007 | 06:43 PM
Default Re: ? - k20 crx - ? (EFinawesomeman)
alrighty, ive been thinking about it for a while now. cant decide if i want to spend probably a good 8 grand to do it.
Old Aug 20, 2007 | 06:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyh0nda &raquo;</TD></TR><TR><TD CLASS="quote">alrighty, ive been thinking about it for a while now. cant decide if i want to spend probably a good 8 grand to do it. </TD></TR></TABLE>
8 grand could get your a 600hp b series.
Old Aug 20, 2007 | 06:58 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyh0nda &raquo;</TD></TR><TR><TD CLASS="quote">are there mounts and everything necessary to do a k20 swap in a crx? is everything made needed for it to run right? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmrCRX &raquo;</TD></TR><TR><TD CLASS="quote">
k20a.org </TD></TR></TABLE>
CRX Bart has a write-up on there, it's also here on HT in the FAQ's
Hasport's Guide for a K20 in an EF is also on http://www.k20a.org
Check out http://www.droppedcrxsi.com He compiled a part's list and some other good info.
Besides welding the passenger mount in, all parts for the hybrid swap are available.
The shift linkage/assembly would take some custom frab work. Karcepts developed a system to work with EG models, but unfortunately, nothing for EF's yet. So you'll have to get creative with that.
Hope this helped!
Mechman456
Sep 26, 2006 04:15 AM
hatchO
22
Feb 6, 2006 09:31 AM
SpankyofNOLA
10
Dec 12, 2004 08:24 AM
wid326
Sep 7, 2004 01:53 PM
