about H&R spacers
cheapest found here:
http://autosportstyle.com/shop....html
also found here for a little more:
http://www.livermoreperformanc...ml#hr
Oh and one more question, Im putting DC5 type R rims on my RSX do i need spacers for every wheels? because I think one set (which costs around $100) only come with 2 right?
Thanks again
Thanks again
H&R spacers are hub centric spacers and have studs on hte spacer it self. You bolt the spacer to your stock hub and your wheel bolts onto the spacer (i hope you understand what i'm saying..) Therefore you do not need extended studs. It's mainly the reason why H&R spacers cost so much other than branding lol..
As for DC5R wheels, you need 15mm all around as the DC5R wheels are 60 offset and stock RSX is 45, unless you do the DC5R brembo + suspension conversion, than you would only need the rears.
I ordered 25mm H&R spacers. They come with nuts to connect to you stock studs and have studs on the actual spacers. I am also using them for ITR rims. It turns the offset to 35mm which does not rub at my height. They are 142.00 for a pair so the total came up to 292 shipped.
Rboosted717
Feb 3, 2004 12:11 AM
travis
Jan 17, 2003 08:37 PM
