finishing my poormans type r built motor...need some suggestions
Old Aug 20, 2007 | 05:40 PM
poormans_typer69's Avatar
Default finishing my poormans type r built motor...need some suggestions
i need to find a itr header....where can i find one for sale..looked on ebay..cant find something close to it...any suggestions on what i should get..
so far i got rebuilt
1. b18c1 block
2. b16 head
added
3. stage 2 cams
4. high compression pistons
5. skunk 2 intake magnifold
6. skunk 2 70 mm throttle body
7.act clutch + flywheel
any other suggestions
Old Aug 20, 2007 | 06:23 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: finishing my poormans type r built motor...need some suggestions (poormans_typer69)
Throttle body's too big, you really don't need more than 65mm on that build. Are you looking for a stock 4-1 tubular style factory header or something like a DC JDM 4-1 header because they should be relatively easy to find, especially on ebay.
Old Aug 20, 2007 | 06:27 PM
Lscivic1999's Avatar
Default Re: finishing my poormans type r built motor...need some suggestions (00Red_SiR)
it sound like NICE SET-UP For me..make sure you tune it right...!!! what tranny are you using???
Old Aug 20, 2007 | 06:57 PM
b16a3delsol's Avatar
Default Re: finishing my poormans type r built motor...need some suggestions (Lscivic1999)
get a good header and a good tune and that will be a sweet ride. not that it already isnt.
Old Aug 21, 2007 | 10:58 AM
Default Re: finishing my poormans type r built motor...need some suggestions (b16a3delsol)
any update???????...
Old Aug 21, 2007 | 04:43 PM
thanks for the info..i guess that i havent searched really good for that header but sure will..i bore my head also and am not sure what kind of head gasket to use but i will soon find out when my machine shop tells me... i know that im going to use a cometic headgasket but dont know how thick...let me know what you used and how many hp are you doing if you dont mind me asking...
Old Aug 21, 2007 | 04:44 PM
im using a sir tranny LSD...with xtreme act clutch and act flywheel
Old Aug 21, 2007 | 04:57 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a3delsol &raquo;</TD></TR><TR><TD CLASS="quote">get a good header and a good tune</TD></TR></TABLE>
Old Aug 23, 2007 | 04:33 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poormans_typer69 &raquo;</TD></TR><TR><TD CLASS="quote">...let me know what you used and how many hp are you doing if you dont mind me asking...</TD></TR></TABLE>
I used a Buddy Club 2 layer headgasket along with a certain amount of head milling to get me to the compression level I needed. I'm still doing some fine tuning with my Hondata setup and haven't yet dyno'd it but I'm confident that it will put down at least 190hp+ at the wheels. With a good header like SMSP, I'm sure I'd be in the magical 200whp range. Either way, the dyno is mainly a tuning tool and the numbers don't mean anything, it's the numbers at the end of the 1/4 mile track that tell the true story.
Old Aug 30, 2007 | 07:26 PM
hey just added dc sports 4-1 headers and i want to know if i will have a problem connecting the throttle body cable to a b16 head from a gsr harness or w.e...i dont know what im saying right now but w.e. if anyone has an idea let me know.. thanks ...
SLOENUF
Nov 22, 2007 11:41 AM
greeneg2.0
19
Dec 19, 2006 04:26 PM
crackerjacker006
Mar 7, 2006 11:46 AM
Lee_Delso
May 15, 2005 06:30 PM
slugzed
12
Aug 19, 2004 10:44 PM
