how to remove rear LCA's?
Old Aug 20, 2007 | 04:43 PM
ek9tl's Avatar
Default how to remove rear LCA's?
Anyone have a step by step layout on how to remove the rear LCA's. I dont want to do move that i shudd have to. Thanks All.
Old Aug 20, 2007 | 04:46 PM
Archidictus's Avatar
Unceasing Measure
Default Re: how to remove rear LCA's? (ek9tl)
It usually helps when you give us a vehicle make and model kid. Either way, there are three bolts you have to remove and possibly a swaybar endlink bolt on each side as well. Prepare yourself for broken bolts and headaches.
Also, you can look it up and stop being lazy. There are tons of how-to's and walk-throughs on this subject.
Old Aug 21, 2007 | 12:20 PM
ek9tl's Avatar
Thanks the car is a 97 honda civic hatch. And i did a search but i didnt find anything. I'm not trying to be lazy..
Old Aug 21, 2007 | 12:27 PM
blaze_125's Avatar
there is no hidden catch in that job. Just take off the 3-4 bolts, remove arm, put in new one, put bolts back on.
The bolts will most likely be seized to death on there. Be prepared to cut them off and put new bolts on.
Old Aug 21, 2007 | 12:28 PM
philosofy1's Avatar
Default Re: (ek9tl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9tl &raquo;</TD></TR><TR><TD CLASS="quote">Thanks the car is a 97 honda civic hatch. And i did a search but i didnt find anything. I'm not trying to be lazy..</TD></TR></TABLE>
i would spray some pb blaster, or wd-40 and let them soak alittle before starting the job.
Old Aug 21, 2007 | 12:35 PM
burnitdown's Avatar
just a few bolts dude. but beware, such a seemingly easy job can turn into a huge pita real quick
pgpunkguy's Avatar
Default Re: (philosofy1)
also helps to have an impact wrench and torch. (heating up the bolts will help break the rust free)
Old Aug 21, 2007 | 12:36 PM
EL Vap133's Avatar
Default Re: (burnitdown)
Old Aug 21, 2007 | 12:39 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: (EL Vap133)
It will also help if you remove the wheel. I tried to replace mine once with the wheel on and the weight of the wheel made it much more difficult to align everything again.
Old Aug 21, 2007 | 01:06 PM
dohcteg's Avatar
Default Re: (24TEN)
Also, remember to use a tq wrench and tq it to specs. I took off my LCA when i was installing the ASR kit and didnt tq it to specs thought it was ok. Good thing i checked every few days after cuz i found out one of the bolts was lose.... many imagine it falling off........................................... that wouldnt be good. So tq it to specs!
Old Aug 21, 2007 | 03:36 PM
ek9tl's Avatar
yea i kno thanks alot guys i appreciate the follow up...
Old Aug 21, 2007 | 04:49 PM
Tonymoto's Avatar
Default Re: (ek9tl)
I'd just take it to a shop unless you have access to an impact wrench.. cause more than likely your going to snap the heads off the lca bolts and be stuck going to a shop anyways
Old Aug 22, 2007 | 12:22 PM
philosofy1's Avatar
Default Re: (Tonymoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonymoto &raquo;</TD></TR><TR><TD CLASS="quote">I'd just take it to a shop unless you have access to an impact wrench.. cause more than likely your going to snap the heads off the lca bolts and be stuck going to a shop anyways</TD></TR></TABLE>
yeah like this is great advice. he has a higher chance of snapping them with an impact wrench than by hand.
Old Aug 22, 2007 | 12:48 PM
EE_Chris's Avatar
Default Re: how to remove rear LCA's? (blaze_125)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze_125 &raquo;</TD></TR><TR><TD CLASS="quote">there is no hidden catch in that job.
The bolts will most likely be seized to death on there.</TD></TR></TABLE>
LOL. That is the hidden catch...that isn't so hidden once you've done it.
And don't forget to load the suspension when re-tightening the bolts. Past that...no hidden catch.
Old Aug 22, 2007 | 03:12 PM
Dann6968's Avatar
Default Re: how to remove rear LCA's? (EE_Chris)
Buy a manual for your car. It will show you how to do almost everything on your car.
slvrlude
Suspension & Brakes
Dec 27, 2007 10:05 PM
ek9tl
Aug 20, 2007 04:35 PM
Jesterian
Dec 28, 2005 12:49 AM
ekdriven
Mar 18, 2005 10:39 AM
Nice_Dc2r
Oct 23, 2003 10:41 AM
